prelude axless in 94 gsr
Old Oct 3, 2007 | 10:45 AM
lilpastrana's Avatar
Default prelude axless in 94 gsr
i snapped my axle and need a filler axle for the meantime, and wondering if a prelude axle will fit. passenger side axle ?
off of a 92-96 prelude w/ abs
to a 1994 gsr w/ abs interchangeable ?
Old Oct 3, 2007 | 11:10 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I highly doubt it will work.
Get a rebuilt one from an auto parts store.
Old Oct 3, 2007 | 11:17 AM
Default Re: (PatrickGSR94)
rebuilt one !!? how do u rebuilt a snapped axle ?
Old Oct 3, 2007 | 11:19 AM
Community Builder
you buy a rebuilt axle from an auto parts store. Axles with good shafts can have the CV joints rebuilt with new components.
Not sure if they would give you anything for core charge on your broken one, though, unless it broke inside the joint and the shaft is still good.
I would suggest rebuilt axles from Advance Auto Parts. The ones from AutoZone and NAPA are notorious for being utter crap.
Old Oct 3, 2007 | 11:35 AM
well i already ordered a new one with a waranty, so i just want something for the weeeknd, just got my crx w/ gsr swap going got on it 1st to 2nd and SNAP! there goes my axle
Old Oct 3, 2007 | 12:44 PM
Default Re: (lilpastrana)
Old Oct 3, 2007 | 01:32 PM
Boostin_GSR's Avatar
Yo you can pick up an axle for like $50 from some auto parts place and get a warranty. That way when you snap another just bring it to them and swap it out.
Old Oct 3, 2007 | 01:39 PM
JasonST's Avatar
Default Re: (Boostin_GSR)
a prelude axle won't fit because the end that goes into the hub is bigger and won't fit in a teg. If ur looking for new axles, I would suggest new ones, not rebuilt, every thread I've read on here about rebuilt axles people seam to say that it's a big gamble because most of the time they eather come with bad cv joints, or go bad very quickly. I even have rebuilt axles because, hey why not it's cheeper, and yup one of the cv joints is bad and cause me vibrations, so.. my oppinion is to spend a bit more money and do it right the first time.
Old Oct 3, 2007 | 02:02 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote"> The ones from AutoZone and NAPA are notorious for being utter crap.</TD></TR></TABLE>
You say this all the time yet some friends that I race with and myself have had great sucess using them at the track on slicks. I have well over 60 passes on the current pair launching at 7K rpms.
BTW- Prelude axles are longer and won't fit. Not to mention the outer hubs are different.....
Old Oct 4, 2007 | 03:58 AM
Community Builder
Default Re: (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
BTW- Prelude axles are longer and won't fit. Not to mention the outer hubs are different.....</TD></TR></TABLE>
Well let's see... I bought one pair from AutoZone and they were the wrong length. I returned them and bought another pair from NAPA (same brand of axle) and it had bad inner joints. I exchanged them 2 more times because every set was either the wrong length or had bad inner joint, and then finally got a set that seemed okay. Out of that set, the driver side axle lasted all of 2 years before ripping the outer CV boot.
So yes, I'm going to say that the CCT brand of rebuilt axle is crap, for the most part. I will still keep using it, though, since I have the lifetime warranty and will continue getting them free as long as they keep taking a dump on me.
My brother got rebuilt axles from Advance Auto for his del Sol (not sure of their brand), and they appeared to be much higher quality than the CCT ones, and even came w/ OEM-style rubber balancers in the middle of the shaft, which the CCT ones never have on them.
Old Oct 4, 2007 | 07:39 AM
skunked's Avatar
My brother got rebuilt axles from Advance Auto for his del Sol (not sure of their brand), and they appeared to be much higher quality than the CCT ones, and even came w/ OEM-style rubber balancers in the middle of the shaft, which the CCT ones never have on them.</TD></TR></TABLE>
NAPA axles are different than AutoZone last time I checked. Like I said no issues and we beat the **** out of them. Only failures I have had is when I snap the shafts in two.
Maybe some people do burnout circles or don't preload to make them fail
Old Oct 4, 2007 | 09:05 AM
p nut's Avatar
I've also heard of the rebuilt axles being a bit iffy on the rebuild quality. I got a new one from Autozone for $99 w/lifetime warranty. Never gave me any problems.
b184life
Aug 18, 2009 08:09 AM
frankenstienEk
Dec 12, 2006 09:19 PM
MugenHonda
Dec 30, 2005 10:38 AM
tekkynikality
Nov 29, 2004 01:59 PM
User 5426
Nov 7, 2003 10:44 PM
