will the power steering pump from a d16y8 fit the bracket on a b18c?
Old Jun 19, 2002 | 05:46 AM
red96's Avatar
Default will the power steering pump from a d16y8 fit the bracket on a b18c?
thanks...
Old Jun 19, 2002 | 04:01 PM
Aceman64's Avatar
Default Re: will the power steering pump from a d16y8 fit the bracket on a b18c? (red96)
what car is the engine from? i know the civic pump wont bolt up. if its a 92-95 civic you will need an integra pump. if its a newer civic you will need a 99-00 si pump. if you look at the pressure line and the bolts and the line are in a straight line then you need an SI pump. if the bolts are straight across and the line is offset in the middle you need an integra pump.
- Ace
MikeFeuti
Mar 21, 2019 07:40 PM
Civicfanatic_09
Aug 12, 2009 09:26 PM
geebs
May 1, 2007 09:57 PM
Timmay
Mar 30, 2006 02:28 PM
NirVTEC
Sep 24, 2003 09:16 PM
