oil question
Old Oct 3, 2007 | 03:57 AM
hondacrx2's Avatar
Default oil question
This will most likely be the dumbiest question on HT. But i have to know. i have a b16 in a crx. And when i check the oil it always changes. if i i check cold it says i have hardly any oil. But if i run it hard it says the same thing. But once in a while when i run it nice and let it cool for 10 min. it shows the oil is fine. what is the right way to check it? sorry for such a dumb question
Old Oct 3, 2007 | 04:23 AM
CRX Toad's Avatar
Default Re: oil question (hondacrx2)
Pull dipstick out, wipe off with towel (or something similar) reinsert dipstick take it back out and look at how much oil you have.
Old Oct 3, 2007 | 04:36 AM
hondacrx2's Avatar
Default Re: oil question (CRX Toad)
i did know that but when should i check right after vtec but then the oil would be in the head, or when its cold, or just run it nice and then check it?
Old Oct 3, 2007 | 05:11 AM
CRX Toad's Avatar
I check it once I shut the car off, or once I come off track with the motor turned off. VTEC has nothing to do with checking your oil and you should always have a little oil in the head otherwise you get dry starts and will kill the motor.
Old Oct 3, 2007 | 05:16 AM
Trakhor's Avatar
Torque Junkie
Check this out
http://www.ehow.com/how_103_check-oil.html
It took Google .20 seconds to find that.
gwarfare
Feb 19, 2013 01:58 PM
dumada9
Jul 5, 2008 11:46 AM
kevin85193
Jun 12, 2005 11:42 AM
samsteinf22a
Jan 27, 2005 05:57 PM
JMinSi2000
Aug 15, 2002 07:49 PM
