Need to know why....
Old Oct 2, 2007 | 05:27 PM
nemesis25's Avatar
Default Need to know why....
Thanks for reading. I need to know, why is it not good to have motor oil above the upper mark on the dipstick?
Thanks.
Old Oct 2, 2007 | 05:37 PM
Rob97'SH's Avatar
Default Re: Need to know why.... (nemesis25)
A little is fine but oil does expand dont know how much> the problem gets when pressure gets to high you blow out seals. Also I think not sure windage becomes a problem.
Old Oct 2, 2007 | 05:38 PM
117's Avatar
117
What seals would get blown out by having the oil level too high?
Old Oct 2, 2007 | 05:41 PM
Rob97'SH's Avatar
Default Re: (117)
Cams, Crank front and rear but pressure would have to be pretty high.
Old Oct 2, 2007 | 07:51 PM
prelude_h22vtec's Avatar
if your oil level is too high, the oil will foam up from getting beat around by the crankshaft. when the oil is foam, and not liquid, the pump cannot push it through the motor. this will starve your engine of oil.
this is called "cavitating the pump"
Modified by prelude_h22vtec at 9:04 PM 10/2/2007
ndex
Jan 28, 2013 06:31 AM
bOOsT-FeIn
11
Oct 30, 2006 06:00 PM
White_EK49
Sep 4, 2006 12:44 AM
tcontesh
Jun 29, 2006 01:46 PM
sleepyhatch00
Sep 2, 2005 01:35 PM
