bolt in timing cover
Somehow I had a bolt break off from the drivers side engine mount on the block, and it got sucked up into the cam and timing cover/valve cover. Got stuck, chewed the belt but nothing skipped or broke (whew). I am going to to Tbelt and water pump since I am in here, any worries about the cam gear?
And in the second pic that shows what bolt broke out, am I safe to run without it, or should I pull this all apart and attempt to extract the rest and put a new bolt in?
Thats for sure, it was fine when I pulled into the garage at night, then go to start it up and go to work the next morning, and its just squealing like a stuck pig so I shut it off and found that.
So should I be afraid of reusing the cam gear? I was thinking of sanding it down and buffing it to see how smooth it comes out, but dont want to have it affect the Timing belt at all.
Probably a dumb question, but would a gear off a H23 cam fit on there the same, or are they different?
You could probably re-use them if you sand/file down the burs. I bet you could find a used set really cheap from someone who has installed adjustable gears.
How did you find this? "weird" noises from the engine?
Good luck.
Good luck.
