Need help ASAP!!!! Ignition problem... Wont crank
Old Oct 2, 2007 | 03:10 PM
310Integra's Avatar
Default Need help ASAP!!!! Ignition problem... Wont crank
I have a 98 integra. And my ignition was broken before. but today as i parked i try to hide it and it went out i guess it touched ground. Now im wondering what fuse is it to make it crank and to open the switch i need to get home im stuck at work and i just need that if i need a fuse I can walk down to pepboys and pick one up or if some one can pass me the diagram of the ignition fuse or relay.
Old Oct 2, 2007 | 03:16 PM
posHonda's Avatar
You could just start pulling fuses to see if any are blown.
Old Oct 2, 2007 | 03:26 PM
310Integra's Avatar
Default Re: (iVteC_PoWeR)
yah ive tried inside of the car all seem to be ok. now i got to check the engine bay. let me know if anyone knows the ignition fuse or relay where its located at in a 98 integra gsr
Old Oct 2, 2007 | 03:43 PM
JasonST's Avatar
Default Re: (310Integra)
There are only the fuses in the fuse box under the dash, and inside the engine bay, if none of those are blown ur problem lies elsewhere. Could be loose ground, or wire related.
Old Oct 2, 2007 | 04:26 PM
310Integra's Avatar
Default Re: (JasonST)
ok heres what happen my ignition is broken. and i just have the swicht which can be turn with anything. I was tucking it in when it made contact with ground and i heard it spark. Now where would the fuse be located I dont have a fuse cover.. thats why or else i would had figured it out.
Old Oct 2, 2007 | 04:37 PM
posHonda's Avatar
There arent that many fuses honestly. You could pull and check all of them in like 5 minutes since you dont have a diagram.
Old Oct 2, 2007 | 06:11 PM
davidv433's Avatar
theres a big fuse under the hood fusebox, i think 50 amp if i can remember, with two screws on each side, blew one b4 while trying to install an alarm. lol
Old Oct 2, 2007 | 07:35 PM
310Integra's Avatar
Default Re: (davidv433)
yah i got it bro. I went to check the engine next and i found it, took me 2 mins to walk to pepboys.. got the 40 amp fuse got back and it was the wrong one, went back with the correct fuse and exchanged it and got an extra one just incase, replaced it and yes my car started.. all i have to do now is replace my ignition cylinder thats why that is happening.. err im pissed in a way. i was almost late today for work and i park to closed to the stopper in front and hit my lip i was like watever. got out and the side top of the bumper and half way it was bended and broken,.. wow., o well what can i put to stop it from cracking the bumper is oem.. idk how it broked,. maybe some silicone??? or some thing else thats harder so i can mold it and paint it doesnt have to be perfect im doing a jdm front in the future
91sedan_kid
Jan 19, 2025 09:13 PM
1badcrx
Jul 26, 2009 10:37 AM
vnguyen850
Mar 4, 2007 07:53 AM
vtec25
12
Apr 25, 2006 03:23 PM
