All Golden Eagles need block notching?
Old Oct 2, 2007 | 02:53 PM
mondo375's Avatar
Default All Golden Eagles need block notching?
Motor: d16z6
Bored:75.5mm
Rods: Golden eagles stamped with 5394.AHO with arp 2000 bolts
What area of the rod hits the block that makes it require notching? What do i need to measure on the rod to know if i need to notch the block or not? I'm searching as i'm waiting for a response to this post.
Thanks in advanced!
Mondo
Old Oct 2, 2007 | 02:58 PM
SIred91's Avatar
Rainman
Default Re: All Golden Eagles need block notching? (mondo375)
You need to take about an 8th of an inch out of the bottom of the cylinders on both sides, to have clearance.
It hits on the edge about where the change from long to round is.....if that makes sense. ?? No picture to chop for you,...
Old Oct 2, 2007 | 03:36 PM
mondo375's Avatar
Default Re: All Golden Eagles need block notching? (SIred91)
thanks!
I notched one side just now, are they supposed to look pretty? Its obvious which cylinder was the first one i hit with the dremel lol. i need to go back and try to smoothen them out a bit lol.
Old Oct 2, 2007 | 03:40 PM
SIred91's Avatar
Rainman
Look around on http://theoldone.com perfect info there....
Old Oct 2, 2007 | 05:10 PM
danmdevries's Avatar
http://theoldone.com/articles/...Ftips/
Old Oct 2, 2007 | 05:38 PM
Chiovnidca's Avatar
Default Re: All Golden Eagles need block notching? (danmdevries)
Old Oct 2, 2007 | 07:30 PM
Default Re: All Golden Eagles need block notching? (Chiovnidca)
Hrmm... that's a different way to do it ^
Old Oct 3, 2007 | 02:59 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danmdevries &raquo;</TD></TR><TR><TD CLASS="quote">Hrmm... that's a different way to do it ^
That was all it needed, didn't see any reason to hog out everything in between.
EG-SIXV-TEC
Aug 24, 2013 11:06 AM
Yeah Daybid
Mar 12, 2010 03:34 PM
td04civic
Jan 4, 2006 07:28 AM
WICKED2
Feb 20, 2002 12:54 PM
