D16z6 eagle h beam rods girdle hits arp bolt??
Old 08-23-2013, 09:05 PM
EG-SIXV-TEC's Avatar
Post D16z6 eagle h beam rods girdle hits arp bolt??
hi i just assembled my d16z6 vitara with bored 75.5mm spec /
when i first put it together the rods only hit the main gridle cap.
so i grind and shaved the main gridle cap a little only.
if i spin the crankshaft with everything installed the eagle H beam rods don't seem to hit the engine block.
i re spin and everything spin freely.
i called arp they said the newer ones don't need to notch the block because of the new bolts. only the gridle cap.
Everything is on block/head etc.
timing belt etc ready to be put in the car also has on the engine hoist.
is the block needed to be grinded notched??
ive already put everything but want to verify if i need to do grind block.
anyone know???
pls let me know thanks.
Old 08-23-2013, 09:13 PM
slowDB7's Avatar
Default Re: D16z6 eagle h beam rods girdle hits arp bolt??
You don't need to notch the block, you will only need to notch the girdle
Seeing as how you already did that, your good to go
Old 08-23-2013, 09:25 PM
are you sure?? can anyone else confirm this lol.
im really paranoid at this point. but anyways thanks
some people told me i had to but made me RE thinking this.
i got the newer style arp bolt and eagle rods/ h beams.
already not touching when turning
did anyone else only notched the gridle??
thanks.....
Old 08-23-2013, 09:38 PM
slowDB7's Avatar
Some more people will probably chime in later, but I'm pretty positive
Old 08-24-2013, 09:06 AM
bump anyone did this only notched the gridle????
pls let me know thanks....
Old 08-24-2013, 09:49 AM
EJ1_Ex's Avatar
Yes you need to notch the block and gridle..
Old 08-24-2013, 09:57 AM
but it didn't hit the block i only notched the gridle...
is it diffrence with the revised version. the newer eagle h beams arp bolts?
ive searched forums and some people says only the gridle needed to be grinded???
i want to confirm this anyone got the newer style arp eagle h beam rods with 75.5mm bored???
Old 08-24-2013, 10:00 AM
EJ1_Ex's Avatar
On my sohc build I had to notch the block and gridle. Rod bolts hit the gridle
https://www.google.com/#fp=ce90971b9...otch+block+d16
Old 08-24-2013, 10:14 AM
https://www.google.com/#fp=ce90971b9...otch+block+d16[/QUOTE]
did you have the d16z6 eagle h beams??? with the newer ARP on the rods???
newer eagle h beam ones???
did it hit the block?? mines don't hit the block???
spins freeley and dont seem to hit the block part??
confused
Old 08-24-2013, 11:06 AM
RACEPAK's Avatar
weird.
beginmyhonda
08-05-2011 08:13 AM
b18c4g
05-11-2007 10:42 AM
CRX_Phantom1
01-30-2006 05:34 PM
93civicEX
03-08-2004 07:09 PM
kwik92hb
12-09-2003 10:05 AM
Quick Reply: D16z6 eagle h beam rods girdle hits arp bolt??
