Safe Rev Limit, LS vtec, a/m valvetrain, ARP's?
Old Oct 2, 2007 | 01:08 PM
warrenh32's Avatar
Default Safe Rev Limit, LS vtec, a/m valvetrain, ARP's?
Hi. I've got an LS vtec with BC Spec 3+'s, Buddy Club valvetrain, ARP head studs and rod bolts and the usual bolt-ons. I know with these cams the power will dip off around 7900rpm, but regardless of that what is the max I can rev to? Thanks
Old Oct 2, 2007 | 01:33 PM
JDM JEFFREY's Avatar
if the power falls at 7900 whats the point on reving the motor higher?
I run my lsv with skunk2 cams too 9000
Old Oct 2, 2007 | 05:45 PM
j spec's Avatar
Default Re: (JDM JEFFREY)
got arp rod bolts in my lsv with portflow springs/retainers and it sees 9k every time i drive it. built by me.
Old Oct 3, 2007 | 01:56 AM
Jdmsoles's Avatar
From: Dodgin Cops all Round Ana-Crime to Orange & Sd
just curious have you upgraded you ignition system because i dont understand how power would fall off at 7.9k with came like that 302 advertised duration and exhaust 294 and 10.71lift doenst really make sense elaborate for me yea...??? you said you have valvetrain work so you have springs and retainers and valves so why would you not be able to have power higher if valvetrain isnt replaced that would explain why since it would be floating..... please explain and clear this hazy bubble!!
vteck1ck
Mar 15, 2010 06:04 AM
lskid98
Sep 17, 2007 05:58 PM
StreetracerVL
Feb 2, 2005 09:13 PM
boosted k20
Feb 1, 2005 08:16 PM
JDM Like Whoa
May 9, 2004 11:23 AM
