B16a stroker question
My homie has a B16a (~203.1mm) block just lying around and I want to put it to good use. I also have a LS crankshaft (89mm) just lying around so I figure what the expletive I might as well build a stroker. My question is what size rods should I use or what customs pistons should I use to make this feasable. I'd rather keep it stock pistons (ITR) and use custom rods but how would I figure out the rod length needed so I could have a set made? any and all imput would be appreciated!
B16 rods, custom pistons.
Rocket designed some really good CP pistons for this setup.
Custom pistons will be a couple hundred cheaper than custom rods. Cunningham rods are about $800-$900 compared to $550'ish for CP's.
alright, that's understandable but I'm trying to get the "dimensions" of what mechanical parts I'd use, rather than pricing on pistons and rods...
It can all be figured out. All you need to know is the stroke, rod length, deck height. Start with the stock piston comp height and pin diameter and go from there.
