Rear-view mirror loose - How to tighten
Old Oct 1, 2007 | 04:29 PM
MikeDawg's Avatar
Default Rear-view mirror loose - How to tighten
Hi,
I have a '97 Honda Civic, and the rear view mirror seems to be awfully loose. It isn't loose enough to move during normal driving, but if I have to flip the switch to "dim" the mirror, the mirror moves all over the place, and in effect, the dimming doesn't work.
Is there a way to tighten the rear view mirror so it doesn't wiggle around so much?
Old Oct 2, 2007 | 09:49 AM
MikeDawg's Avatar
Default Re: Rear-view mirror loose - How to tighten (MikeDawg)
bump.
Old Oct 2, 2007 | 09:54 AM
jdm91CrxSi's Avatar
get fast drying super glue, position it where you want it and wala! the job is now done..
Old Oct 2, 2007 | 10:01 AM
MikeDawg's Avatar
Default Re: Rear-view mirror loose - How to tighten (jdm91CrxSi)
On the civic, the rear view mirror isn't actually attached to the front window, it is actually attached above the windshield. If you look at:
http://www.hondaautomotivepart...81%29
I guess it is calling the bar that holds the mirror a "stay", but I don't see any way to adjust it.
Old Oct 2, 2007 | 10:12 AM
jdm91CrxSi's Avatar
and what year is your vehicle?
Old Oct 2, 2007 | 10:17 AM
MikeDawg's Avatar
1997 Honda Civic EX
Old Nov 22, 2007 | 08:47 AM
skypros's Avatar
Ok I just had to do this on my '98 civic
* get something flat and GENTLY pry the plastic piece that is against the headliner CORNER on the front (towards windshield)
Now remove the (3) philips head bolts.
Now that you have the whole rear view mirror in you hands....... there is a black plastic piece that covers the mirror ball adjustment...... there is a place to put a flat blade screwdriver and pry the piece off....
Now you have access to the adjustment..... the small philips bolt will adjust (tighten/loosen) the mirror........ If you tighten all the way and it is still too loose..... take the flat plate off and BEING CAREFUL...... SLIGHTLY bend the metal.... REMEMBER slightly....
Hope it works for you.... it worked for me
Old Nov 16, 2011 | 06:05 PM
MegasXLR's Avatar
I know someone answered this like a bajillion years ago, but here's a link if someone ever looks this up again. Comes with pictures. :D Hope this helps.
http://www.georgebelton.com/6g.civic...view/index.php
Old Nov 17, 2011 | 10:23 AM
Geo4k's Avatar
Nice - I have the same problem. I copy/paste all of these kind of things to a Word document and save to a file.
PS: Love the part about dog!
Old Nov 21, 2011 | 10:22 PM
MegasXLR's Avatar
Good stuff right? Haha
Old Mar 1, 2012 | 07:47 AM
squeaks's Avatar
great thread
Old Oct 26, 2017 | 11:43 PM
Smithcraft's Avatar
Sorry for the necropost, but I just did this fix ( 6th Gen (6G) Honda Civic Rear View Mirror Vibration Fix ) earlier this evening.
I used three layers, as one or two layers still seemed to be not as tight as I would want.
Saturday night will be the test when I drive home at night!
SC
Deering
Sep 17, 2017 06:24 PM
miamirice
18
Nov 19, 2013 12:13 PM
civicsmoke
Feb 11, 2011 11:58 AM
impound
Sep 4, 2010 06:10 AM
mfishman93
Jan 20, 2008 04:22 PM
