no iacv or tps?
Old Oct 1, 2007 | 03:48 PM
Lordofdark176's Avatar
Default no iacv or tps?
ok so i made another thread about this but nobody looked, my iacv is messed up i think, when i try to start my car it just stalls out immediatly, if i start it with the iacv unplugged it idles really low, stalls when i give it gas but stays on, if i start it with the tps and iacv unplugged it idles fine, revs without stalling (but revs really bad, like laggy and slow) and seems to idle without stalling so far, so would i be fine to drive it around for now until i can get a new iacv (which is what i think is the problem)? help!
Old Oct 1, 2007 | 04:31 PM
standbackimapro's Avatar
You can drive it
Old Oct 1, 2007 | 04:52 PM
forcefedferio's Avatar
Default Re: (standbackimapro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro &raquo;</TD></TR><TR><TD CLASS="quote">You can drive it</TD></TR></TABLE>
you can but why would you? you are just asking to break down.
Old Oct 1, 2007 | 05:53 PM
Default Re: (forcefedferio)
it drove fine on my test drive, wont rev over 2500rpm though so im assuming hondata is running in limp mode with both sensors unplugged. so if i try to plug in just the tps sensor, it starts up for a second, then dies out, if i try just the iacv it'l start up and die out and if i try both, same thing, if i unplug both it'l idle and everything fine. i also wasnt thinking and tried plugging the iacv in with the car running (didn't do this with the tps), so could i have fried the iacv? when i did it the car made a lound noise (bang or poping i think?), stalled out immediatly and i could hear a humming noise from under the hood which i could not locate where it was coming from, humming went away when the car was turned off. any ideas?
Old Oct 1, 2007 | 07:38 PM
Default Re: (Lordofdark176)
up!
Old Oct 21, 2007 | 12:45 PM
duefuss's Avatar
make sure your plugging the right connectors in whats your cel codes throwin?
Old Oct 21, 2007 | 12:59 PM
HondaKid936's Avatar
Default Re: (duefuss)
sounds like we have a similar problem some one told me to clean it out but now my **** dont even start up lol id jus replace it or u might jus have the plugs in the wrong sensor? lmk how it goes for ya
Old Oct 21, 2007 | 01:19 PM
b16a3delsol's Avatar
check the simple things like if the plugs are in the right places, check any cels and correct them, and make sure it is time on the distributor if it has been turned any.
Old Oct 21, 2007 | 01:34 PM
Redbone's Avatar
New TPS FTW? If the TPS is keeping the car from even staying running then I would assume that should be the FIRST piece to replace.
smokinloc
Mar 8, 2010 01:39 PM
TrueUntilDeath.com
Sep 25, 2009 09:13 AM
invisible
10
Mar 17, 2007 11:22 PM
vtec.dc2
Dec 25, 2004 03:33 PM
decipher_this
Jun 24, 2004 08:46 AM
