Need help with my cars idle
Hey my car wont keep the idle at a constant rpm. It will vary from 1500 to 500 and will just start shaking. I know it should vary a little bit once it gets running but i doubt it should be this much. I ran some engine cleaner through it and changed out the spark plugs and wires but it didnt help. Any ideas? Thanks guys
Re: Need help with my cars idle (david90)
i took off my iac and cleaned it and everything and put it back on, I also changed out my PVC valve. Im still searching for ways to do it but i dont wanna try expensive stuff like the MAP Sensor untill I know there is no other choice. Thanks though, any other ideas?
Re: Need help with my cars idle (decipher_this)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by decipher_this »</TD></TR><TR><TD CLASS="quote">Hey my car wont keep the idle at a constant rpm. It will vary from 1500 to 500 and will just start shaking. I know it should vary a little bit once it gets running but i doubt it should be this much. I ran some engine cleaner through it and changed out the spark plugs and wires but it didnt help. Any ideas? Thanks guys</TD></TR></TABLE>
Is your car stock? I believe some mods can cause this to happen.
AllMTRWH0R3
08-04-2004 03:40 PM
