what size rotors/pads for CTR 5 lug?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydakid86 »</TD></TR><TR><TD CLASS="quote">im doing the 5 lug conversion on my 97 civic coupe this weekend and just want to know what rotors and pads i can use? </TD></TR></TABLE>
i believe they are the same has the itr. not sure though, can anyone verify?
where's Blueintegraboy when you need him?
someone else told me the same thing but they were unsure as well. should i swap anything else like the master cylinder/brake booster, 40/40 valve?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydakid86 »</TD></TR><TR><TD CLASS="quote">someone else told me the same thing but they were unsure as well. should i swap anything else like the master cylinder/brake booster, 40/40 valve?</TD></TR></TABLE>
not sure if the 00 si has a 1" M/C, but if so you may want to swap out the M/C and booster. as for the prop valve, the si would be a good one as well.
stay away from intgegra 1" boosters, unless you want to have custom lines made up for them.
jdmxGod
10
Jan 30, 2006 09:34 PM
