What injectors for 2.0 liter motor?
Old Jun 18, 2002 | 07:58 PM
BlackGSR's Avatar
Default What injectors for 2.0 liter motor?
What injectors should I get for a high compression (12:1) 2.0 liter motor - tuned with a Hondata?
What stock work?
I'm looking for 210+ WHP.
Old Jun 18, 2002 | 08:18 PM
1 2 NV's Avatar
Default Re: What injectors for 2.0 liter motor? (BlackGSR)
310s or 370s.
Old Jun 18, 2002 | 08:22 PM
BlackGSR's Avatar
Default Re: What injectors for 2.0 liter motor? (hondaatwsu)
What size are Prelude injectors?
Old Jun 18, 2002 | 08:23 PM
Conechaser's Avatar
290s i beleive
1 2 NV's Avatar
OBD1s i think r 310 and OBD2 r 270
Old Jun 18, 2002 | 08:24 PM
Hybrid ctr's Avatar
Prelude = 280-290cc
If your gonna be running hondata, you could use 440cc injectors.
Old Jun 18, 2002 | 08:26 PM
gsr98vtec's Avatar
Default Re: What injectors for 2.0 liter motor? (Hybrid ctr)
not even close 440 or 550cc. i have a 2.0L and i am pretty much maxed my 440's. and i am running hondata
Old Jun 18, 2002 | 08:31 PM
Hybrid ctr's Avatar
Default Re: What injectors for 2.0 liter motor? (gsr98vtec)
same thing with sgT
hmmmmm I guess 550cc would be your best bet
Old Jun 18, 2002 | 08:36 PM
BlackGSR's Avatar
I didn't know that 440 are necessary for a 2.0 liter motor. I used STOCK injectors when I had Toda "B" with no problems.
I'll be running ITR cams. So, the vote is 440s?
Hybrid ctr's Avatar
what's your setup????
Old Jun 18, 2002 | 08:38 PM
gsr98vtec's Avatar
listen you need 440's or higher with big cams, i am only running jun 2 and switching to toda b's and i am out of useable fuel really. if you dont believe me i will post some dataloggin files tomorrow of my car with the 440's and the jun 2 cams. my setup puts 220whp and 154 ft lbs.
Old Jun 18, 2002 | 08:41 PM
BlackGSR's Avatar
Here's my setup:
1. Resleeved (GE) - 84.5
2. 11.7 Compression, Eagle rods
3. STOCK ITR head
4. ITR cams
5. JDM Mugen header
6. Hondata
440s with ITR cams?
Old Jun 18, 2002 | 08:43 PM
Hybrid ctr's Avatar
Are you gonna stick with that setup???
Old Jun 18, 2002 | 08:46 PM
gsr98vtec's Avatar
its easy to back down fuel psi than to run real high psi at the rail. bigger injectors and 50psi is better than small injectors and 75-80psi.
Old Jun 18, 2002 | 08:50 PM
Hybrid ctr's Avatar
Good info:
http://www.rceng.com/technical.htm
Old Jun 18, 2002 | 08:53 PM
gsr98vtec's Avatar
i get 398cc with 50psi at the rail. so 440 will work just fine and you will run a little rich using 0.50 bfsc which is probably a good thing. do the math, remember hondas lose about 20% of the hp from the crank to the wheels so enter about 260 for a 210whp motor....260*.2 = 52 ..... 260-52 = 208whp
[Modified by gsr98vtec, 12:54 AM 6/19/2002]
Old Jun 19, 2002 | 04:34 AM
Mike K's Avatar
gsr98vtec: hey, whats up man. what kind of fuel pressure are you running? what kind of a/f ratio did you have on the dyno? when we did mike m's B20, he was running 310cc injectors at 48psi, and in VTEC his A/F was a constant 13.0-13.1:1
granted, he still needed a bigger header and more tuning, but we got 210.8hp and 147.7tq at the wheels. he DEFINITELY had enough fuel.
Old Jun 19, 2002 | 06:30 AM
FAST94GSR's Avatar
New User
Default Re: What injectors for 2.0 liter motor? (Mike K)
bring that chit to orlando , lets see what it runs!!!
Old Jun 19, 2002 | 06:33 AM
12 oz.'s Avatar
Default Re: What injectors for 2.0 liter motor? (FAST94GSR)
stock injectors will handle with that setup, but id step up to 310s
Old Jun 19, 2002 | 06:39 AM
Mike K's Avatar
well, gsr98vtec has been here a couple times, and i am sure he's gonna visit again.
we should all get a drag strip meet planned. it would be fun.
maybe we can do it around the time of the Warped Tour? that's early August and the Warped Tour will be hitting Tampa and Orlando. About 50 bands playing. Good ****.
Old Jun 19, 2002 | 10:22 AM
gsr98vtec's Avatar
perfect i am down for that, i will have my 15in wheels by then and i'll put in my ats 4.9. i'll bring that **** down for sure. mike i am at 13.5:1 so i guess thats a little lean maybe, but i dont know how accurate rosens a/f meter is on the dyno. btw. i will be in naples next weekend with jill, keep your phone on so we can meet up, havent seen you,chris,mike or josh in a while. oh, i got the fedex package the other day, thanks bro, got that out before the **** went under....set something up for the warp tour i love that ****, saw it the last 2 years
96redgsr
Jul 21, 2004 09:46 PM
blykins
31
May 4, 2004 06:41 AM
GapxGuy
16
Apr 21, 2004 11:33 AM
Twigster311
Apr 30, 2003 03:54 PM
B20LS-T
Apr 22, 2002 04:24 PM
