Fuel pressure an Turbo cars...
Old Sep 30, 2007 | 05:03 PM
DrivinVtec's Avatar
Default Fuel pressure an Turbo cars...
I was talking with this guy last nite an he told me that I need t set my Fuel pressure accordingly. He said some thing like for lbs of boost you have to adjust you pressure or soem ****. idk what he was talking about. I kinda understand the fpr get will have positive pressure under boost but not understanding it.
Old Sep 30, 2007 | 05:53 PM
DrivinVtec's Avatar
up
Old Sep 30, 2007 | 06:22 PM
locash's Avatar
Default Re: Fuel pressure an Turbo cars... (DrivinVtec)
As long as you have a vacuum/boost referenced regulator, you'll be fine. The most important part of the equation is proper tuning.
Old Sep 30, 2007 | 06:24 PM
DrivinVtec's Avatar
Default Re: Fuel pressure an Turbo cars... (locash)
all i got is a B&M fpr. shoudl I just throw a stock one on?
Old Sep 30, 2007 | 06:32 PM
HybridKOOP's Avatar
Base pressure should be near stock. You can use your stock regulator which is a 1:1 reference, which means that for every pound of boost the regulator sees, it'll raise fuel pressure by 1psi.
Old Sep 30, 2007 | 06:36 PM
DrivinVtec's Avatar
Default Re: Fuel pressure an Turbo cars... (HybridKOOP)
and that what I want right? could i stil use the B&M?
Old Sep 30, 2007 | 06:39 PM
Topdawgg's Avatar
dont need an aftermarket regulator at all...
just make sure you have proper tuning, and the regulator has a proper vacuum source.
Old Sep 30, 2007 | 07:03 PM
DrivinVtec's Avatar
Default Re: (Topdawgg)
thanks. for my next question. are all honda fuel regs the same. i think i have a stock h23 one.
Old Sep 30, 2007 | 07:11 PM
xenocron's Avatar
Default Re: (DrivinVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec &raquo;</TD></TR><TR><TD CLASS="quote">thanks. for my next question. are all honda fuel regs the same. i think i have a stock h23 one.</TD></TR></TABLE>
No...most are around 41-43 psi, some of the ITR and Accord (i think) are up to 50 psi
Old Sep 30, 2007 | 07:28 PM
DrivinVtec's Avatar
Default Re: (xenocron)
what about 4th gen prelude. h23a1 i think
Old Sep 30, 2007 | 07:58 PM
xenocron's Avatar
look it up
Old Sep 30, 2007 | 08:04 PM
DrivinVtec's Avatar
you been no help at all.......................
haha jk
boost4s2k
Jul 29, 2009 11:59 AM
elpiar
May 30, 2006 12:25 PM
hotimportcrx
Feb 4, 2005 08:31 PM
variablevalve
Jun 8, 2004 04:36 PM
J.R.
Mar 18, 2003 04:38 PM
