Mild build on GSR
Old Sep 30, 2007 | 03:36 PM
hatch is best's Avatar
Default Mild build on GSR
Want to do a mild build on a GSR budget is a very big factor.
This is what I want to do:
1. Crower cams 63413-2 Stage 3 - All-Motor Drag Race profile (only because I am getting a good deal on them)
2. Either BC or crower springs & retainers
3. ITR pistons with a two layer gas kit that should give me 11.8 compression
(what to go this way because I don’t what to change rods)
4. Hondata S200
5. Throttle body 68mm
What I have already
1. I/H/E -E 2"1/4 H-ITR
Any thoughts or advice on the above
Old Sep 30, 2007 | 03:48 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Mild build on GSR (hatch is best)
Those cams are not optimal for your motor.
2.25" is going to restrict your motor alot.
Is it a JDM ITR header?
Old Sep 30, 2007 | 03:55 PM
Default Re: Mild build on GSR (mar778c)
JDM ITR header - yes
why not the crower cams, is it too aggressive?
Old Sep 30, 2007 | 04:01 PM
Chris Tune's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch is best &raquo;</TD></TR><TR><TD CLASS="quote">
please explain why would it require to change rods for what?
Old Sep 30, 2007 | 04:05 PM
Default Re: Mild build on GSR (Chris Tune)
after market higher pistons always recommend changing of rods
Old Sep 30, 2007 | 04:12 PM
Chris Tune's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch is best &raquo;</TD></TR><TR><TD CLASS="quote">after market higher pistons always recommend changing of rods</TD></TR></TABLE>
yeah and electromotive says that cam gear triggers are for low rpms too
Old Sep 30, 2007 | 05:18 PM
mar778c's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch is best &raquo;</TD></TR><TR><TD CLASS="quote">why not the crower cams, is it too aggressive?</TD></TR></TABLE>
Yes, this build is a by your admission a "mild" street set-up. Those cams require a motor that can flow a lot of air.
Unless, you plan to rev to 11K get a milder set of cams.
Old Sep 30, 2007 | 06:07 PM
dc2_dude's Avatar
im doing the same build next week, but using either ITR cams or s2s2
gsr95
Feb 4, 2008 02:41 PM
delsolturbo
Feb 13, 2006 10:20 PM
Champ White EJ8
20
Feb 17, 2005 05:01 AM
boostin4door
Jan 30, 2005 08:40 PM
jaydmcrx
Jan 17, 2005 11:31 AM
