Help with 96 civic wind noise
Old Sep 30, 2007 | 01:39 PM
IheartFLATblack's Avatar
Default Help with 96 civic wind noise
I have a 96 civic sedan and when driving 50 mph or faster, I get a lot of wind noise coming from my driver's side front window. I have manual windows and if I crank the window closed a little harder it stops but won't stay like that without me holding the crank. Is there something I can do to stop this noise like an adjustment? I'd rather not replace the window moldings because they're expensive and a pain in the *** to replace. I've thought about putting a strip of tape on the top part of the window to make a better seal but that's kind of ghetto. Any suggestions?
Old Sep 30, 2007 | 03:06 PM
hondamark35's Avatar
Default Re: Help with 96 civic wind noise (IheartFLATblack)
my first guess would be the two 10mm bolts that hold the window to the to the "scissors" could be loose. you would need to take the door panel off and crank the window up or down untill you can see the bolts through the access holes. make sure they are snugged up pretty well. you don't want to strip the out though.
if those bolts are tight, then you need a new regulator. i think the pivot wears out, or the gears can wear out too.
hand-crank windows are pretty simple, there's not much to pick from that could cause your problem
Old Sep 30, 2007 | 03:22 PM
97civicdx's Avatar
Is the actual sheet metal door window frame bent? If it does that, the glass wont seal right and it doesnt sit right in the weatherstripping
Old Sep 30, 2007 | 04:39 PM
Neptronix's Avatar
I have this issue.
In mine ( a coupe with power windows ), it's the weather stripping / rubber window seal.. there is this little bend in it. pain in my ***.
Old Sep 30, 2007 | 11:02 PM
Default Re: Help with 96 civic wind noise (Neptronix)
Well, I don't think that the door is bent at all, there's no signs of an accident. But it does seal up when I hold the crank tightly closed. I'll try to check the bolts when I get time. Any other suggestions?
Old Oct 5, 2007 | 01:50 AM
any other suggestions? TTT...
Old Oct 11, 2007 | 10:35 PM
mv1luv's Avatar
If your car has been broken into most likey it damaged the guides above the window frame. look into checking that,
lodom
Oct 5, 2010 04:34 PM
00zzySi
Sep 28, 2010 09:43 PM
abdulmo86
19
Oct 18, 2006 09:35 PM
PupaScoopa
Audio / Security / Video
12
May 7, 2003 11:41 AM
NuclearB18B
Jun 6, 2002 11:11 PM
