Which of these 2 flywheels for all motor
Old Sep 30, 2007 | 12:32 PM
7rrivera7's Avatar
Default Which of these 2 flywheels for all motor
Specs:
B18b block sleeved and bored to 84.5mm
Crank girdle with AEBS main studs
Balanced, chamfered, polished crank
ATI crank damper (on its way)
Eagle rods with ARP bolts
CP 12.5:1 84.5mm pistons
Alaniz Competition VTEC head
Skunk2 valetrain
Type R valves
AEBS 68mm throttle
Edelbrock Performer X intake
BPI stack on 3" piping
Hytech replica header (selling for SMSP)
2.5" custom mandrel piping into Magnaflow resonator and Vibrant muffler
RC 370cc injectors
Hondata s300
Skunk2 Stage 2, Skunk 2 Pro 1 & Buddy Club Stage 5 (haven't decided)
Del Sol hydro tranny with 4.78 final
Competition Cluch stage 4 strip clutch assembly
I have both ACT 8lb and 12lb flywheels. Please tell me which flywheel I should use based on the following:
1 - Daily driver
2 - Weekend 1/4 mile drag
Thanks in advance for replying to my post
Old Sep 30, 2007 | 12:58 PM
goldegg's Avatar
I have an 8 lb on my daily driver.
I love it, and would get another again in a second.
The only downside to it I find is starting on hills is a bit harder.
Old Sep 30, 2007 | 01:26 PM
Jay_Sensing's Avatar
12 lb or stock.
I tried them all on my car, the stock lightened flywheel results in the best ET or any of them. The MPH stays the same on the runs but the 60 ft time dropped off even launching at 7800 rpms due to the lighter flywheels not having enough inertia.
Lost close to 3 full tenths with the 8 lb from stock. Car would bog at each shift on slicks. It was fine driving around on the street and throttle response was nice but for drag racing, not my cup of tea.
Old Sep 30, 2007 | 01:51 PM
JDM JEFFREY's Avatar
Default Re: (Jay_Sensing)
act 8lbs you will love it
thats all i use in my motors
Old Sep 30, 2007 | 02:28 PM
Teamdiesel's Avatar
Default Re: (JDM JEFFREY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM JEFFREY &raquo;</TD></TR><TR><TD CLASS="quote">act 8lbs you will love it
thats all i use in my motors</TD></TR></TABLE>
have you experienced any dropped times or 60ft with an 8lb flywheel? Or do you use it because it builds the revs faster?
Old Sep 30, 2007 | 04:44 PM
Default Re: (Teamdiesel)
on my 1.8 I did drop 60 foot from a 1.78 to 1.82
but on the 2L motor it back down to 1.7s
I think tq had alot to do with it .
and yes I use it to build up revs faster..
Old Sep 30, 2007 | 05:05 PM
Not to be argumentative, but my 81.5 made retarded tq numbers. 154 ftlbs at the wheels.
The 60's with the normal flywheel stay about 1.70x with the light about 1.75x or so but even spraying the car out of the hole with the light one it just didn't work as well.
If I road raced the car, I would be all over them because of the throttle response but it just didn't work out well drag racing.
Old Sep 30, 2007 | 05:10 PM
those are big tq number for a 1.8 I made 126 on dyno jet and 146 on dynopack
Old Sep 30, 2007 | 10:34 PM
n1_egsex's Avatar
* B A N N E D *
i use a fidanza 7.5lb on my 98 spec ITR motor (pretty stock) and i love it, it's a street car that will see a road course soon
Old Oct 1, 2007 | 02:59 PM
ls-vtec-delsol's Avatar
i tried both on my ls-v. Go with the prolite, response time alot better.
Old Oct 2, 2007 | 11:01 AM
7rrivera7's Avatar
Default Re: (ls-vtec-delsol)
Bump for more experience
Old Oct 2, 2007 | 11:21 AM
Chillinit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing &raquo;</TD></TR><TR><TD CLASS="quote">12 lb or stock.
Lost close to 3 full tenths with the 8 lb from stock. Car would bog at each shift on slicks. It was fine driving around on the street and throttle response was nice but for drag racing, not my cup of tea.</TD></TR></TABLE>
Jay, I tried explaining this to people on here before however no body agreed.
Old Oct 2, 2007 | 11:23 AM
98vtec's Avatar
moderator emeritus
i've driven 8lbs and 12lbs. couldnt stand the 8lbs because it just made daily driving more of a hassle than its worth. I have zero complaints about the 12lbs.
Old Oct 2, 2007 | 11:59 AM
Aquafina's Avatar
Default Re: (98vtec)
I like my 7.5lb. I'd go lighter if I could. It along with a 6-puck and Omni CMC were fine to DD.
Not real good since I did the clutch at the same time, but here you go...
https://honda-tech.com/zerothread?id=1638578
Slower 60. Quicker 1/8 and 1/4, but slower trap.
Old Oct 2, 2007 | 01:13 PM
7rrivera7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls-vtec-delsol &raquo;</TD></TR><TR><TD CLASS="quote">i tried both on my ls-v. Go with the prolite, response time alot better.</TD></TR></TABLE>
Prolite as in 12lbs right?
Old Oct 2, 2007 | 07:50 PM
Runnerdown's Avatar
Default Re: (7rrivera7)
I rock the act prolite . The only time I did not like the light flywheels was on my turbo cars.
Old Oct 3, 2007 | 05:11 AM
7rrivera7's Avatar
Default Re: (Runnerdown)
I'm going with the Streetlite flywheel at ~12lbs
7rrivera7
56
Dec 13, 2007 07:30 PM
7rrivera7
12
Dec 6, 2007 04:45 PM
7rrivera7
24
Nov 14, 2007 04:47 AM
7rrivera7
10
Oct 30, 2007 04:34 AM
7rrivera7
26
Sep 18, 2007 10:34 AM
