Fuel cut off switch question
Old Sep 29, 2007 | 05:07 PM
Mikes2000civicsi's Avatar
Default Fuel cut off switch question
hey guys,im installing a fuel cut off switch like the 1 from the faq..he uses a 25a switch and i just bought a 10a from radioshack cuz they didnt have any 25...will it work?
Old Sep 29, 2007 | 06:39 PM
Luserkid's Avatar
Default Re: Fuel cut off switch question (Mikes2000civicsi)
I wouldnt run less then 15A as that is the fuse that honda uses. 10A should do it but keep a watchful eye on the switch.
Old Sep 29, 2007 | 07:03 PM
rivaladore's Avatar
its not going to hurt anything.........if anything the relay will be susceptible to going bad bc of the lower amp rating........going with a higher amp relay is bad bc it will allow more current to flow through the devices/wires causing them to get effed up.......laymens terms by looking at the theory behind fuses.--->say honda engineered a particular device to work safely at 15A...they'll then have a fuse for that circuit that will blow/pop if the circuit goes above the 15A rating.......so all in all using a lower rated relay will if anything just go bad on ya but not do anything damaging
socalrex88
Audio / Security / Video
Mar 2, 2008 01:50 PM
92integraVTECgsr
Oct 10, 2005 09:14 PM
GR_DC2
May 27, 2004 10:51 PM
TurboTurtleGSR
Jan 17, 2003 09:04 PM
ionic_slim
May 29, 2002 08:10 PM
