Sohc Tranny Question
Old Sep 29, 2007 | 04:59 PM
ALLMOTOR EK's Avatar
Default Sohc Tranny Question
Im bout to buy a sohc tranny. Guy told me it was off a 95 DX civic. The sticker on the tranny says S20. Isnt that a 92-95 Civic EX/SI? I need this tranny for my 99 Civic ex motor. Will this tranny bolt right up with no problems?
Please let me know asap
Thanks guys
Old Sep 29, 2007 | 05:03 PM
rivaladore's Avatar
Default Re: Sohc Tranny Question (ALLMOTOR EK)
s20 is the 92-95 ex/si tranny..........it will bolt up no problem
CivicUtah's Avatar
* B A N N E D *
all i know is all d series trannies should bolt right up do a d series motor no problem.
why not get the 96-00 ex tranny? short gear ratio's
Old Sep 29, 2007 | 05:12 PM
Default Re: Sohc Tranny Question (CivicUtah)
i havent found a 96-00 ex tranny for a good deal. Plus this tranny is local and only $100
and thanks for the replies guys
Old Sep 29, 2007 | 05:49 PM
Jim Truett's Avatar
Default Re: Sohc Tranny Question (rivaladore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rivaladore &raquo;</TD></TR><TR><TD CLASS="quote">s20 is the 92-95 ex/si tranny..........it will bolt up no problem</TD></TR></TABLE>
No, S20 is just the generic code for a 5th gen D series transmission.
You can tell a DX/CX/VX tranny from a EX/Si by numbers cast into the housing. Just above the filler plug is a set of numbers.
P20/A000 is for DX/CX/VX
P20/B000 is for EX/Si
Old Sep 29, 2007 | 05:52 PM
jdmracer12's Avatar
the s20 trans is for <U>ALL</U>92-95 civics and delsols. you have to look above the passenger side axle input on the trans case and look for a "B000" stamped into it. B000 means an ex/si trans. "A000" means DX, CX, S trans.
Old Sep 29, 2007 | 05:53 PM
jdmracer12's Avatar
Default Re: Sohc Tranny Question (Jim Truett)
damn beat me to it
Old Sep 29, 2007 | 07:25 PM
rivaladore's Avatar
Default Re: Sohc Tranny Question (jdmracer12)
sorry i was misinformed then........thanks for the correction
mods should really delete ALL reply's/threads that have wrong info in ......bc i definitely read multiple posts that said the s20 was only the 92-95 ex/si tranny
Old Sep 29, 2007 | 08:54 PM
thanks guys
delslo93
Nov 2, 2006 08:17 AM
GdmLaz
26
Nov 15, 2005 02:23 PM
StRacer
May 4, 2004 01:04 AM
