E-Brake mod...
Old Jun 18, 2002 | 02:07 PM
Tommy_Gunns's Avatar
Default E-Brake mod...
Is there a way to mod your e-brake so that it does not lock in the up position? I think the cusco ebrake button pictured below does this. I think it would be a beneficial mod for taking hairpins at autocross.
Comments?
-Tommy puts on his flame suit
Old Jun 18, 2002 | 02:11 PM
CPR's Avatar
CPR
Default Re: E-Brake mod... (Tommy_Gunns)
Why don't you just hold onto the handle and keep the button depressed?
Old Jun 18, 2002 | 02:16 PM
Padawan's Avatar
Darth ModerVader
Comments?
No flaming, but wouldn't such a mod make the e-brake useless for anything other than autocrossing (e.g. parking)?
Old Jun 18, 2002 | 02:17 PM
Default Re: E-Brake mod... (Spec.R 00-0123)
I live in the flat lands of Canada. I can always just put it into first when parking (that's what I used to do with my old car which had ebrake problems).
Old Jun 18, 2002 | 02:23 PM
Warren's Avatar
Wrong-Way Wang
E-braking is the slow way to get around paved surfaces.
Left foot braking is what you're looking for. Try not to total the car the first time you try it.
Warren
Old Jun 18, 2002 | 02:26 PM
Default Re: E-Brake mod... (Warren)
I thought about this, but I'm going at such slow speeds. I'll give it a try next weekend during my fun run and see what happens (crosses fingers).
Warren
Old Jun 18, 2002 | 05:09 PM
itr1275's Avatar
Don't do that, you will kill yourself and ruin your tires. Not nessecerly in that order.
Old Jun 18, 2002 | 05:22 PM
Hybrid ctr's Avatar
Default Re: E-Brake mod... (itr1275)
Can someone explain exactly how left foot braking is done and in what situations it's used???
Old Jun 18, 2002 | 05:28 PM
done's Avatar
Default Re: E-Brake mod... (Hybrid ctr)
Old Jun 18, 2002 | 06:21 PM
EPGONZALEZ's Avatar
Default Re: E-Brake mod... (Jordo)
once in the desired gear, you drive your car like a go-kart...
leaving your left foot on the brake..
very good for autocrossing...as long as the course doesnt require you dont need to shift alot
[Modified by EPGONZALEZ, 7:22 PM 6/18/2002]
Old Jun 19, 2002 | 12:25 AM
itr501's Avatar
Default Re: E-Brake mod... (zyg)
does Cusco make this for the R?
Old Jun 19, 2002 | 12:47 AM
Default Re: E-Brake mod... (itr501)
Yes, it says they have one for all Honda models.
Old Jun 19, 2002 | 03:23 AM
primoEF's Avatar
tried left foot someone almost slammed into my rear
Old Jun 19, 2002 | 03:26 AM
DutchITR1689's Avatar
Ehhhh. Why don't you put some duct tape on the **** while keeping it pressed in.....
Old Jun 19, 2002 | 06:15 AM
AssPenny's Avatar
Default Re: E-Brake mod... (DutchITR1689)
Why not just remove the ratchet part of the ebrake
Old Jun 19, 2002 | 06:18 AM
sackdz's Avatar
Default Re: E-Brake mod... (AssPenny)
OT:
Anybody try the FWD forward-donut methood with the fast food trays? You need your ebrake for that. Call me a stunna but it looks fun as hell.
sack-who must try at least once
[Modified by sackdz, 10:18 AM 6/19/2002]
Old Jun 19, 2002 | 06:19 AM
AssPenny's Avatar
Default Re: E-Brake mod... (sackdz)
Havent tried that method... but reverse donuts are nicey nice...
Craig - Who knows vtec works in reverse
Old Jun 19, 2002 | 06:22 AM
sackdz's Avatar
There's another thing! Pointless, slightly harmful thing you can do to your car but gotta do at least once...
I always ***** out at around 4.5k because reverse whines like a sunuvagun. Still have yet to do it. But when I do, I'll be sure to crank the wheel and *M*A*S*H* IT!
[Modified by sackdz, 10:23 AM 6/19/2002]
Old Jun 19, 2002 | 06:41 AM
Warren's Avatar
Wrong-Way Wang
You use it when you need to slow down just a little bit, but not enough to downshift. You stay on the throttle (not necessarily WOT), and squeeze the brake with the left foot. You have to have a well trained left foot, because most people will mosh on it like a clutch pedal, and you'll probably scare the **** out of yourself and everyone around you, and/or crash.
Warren
Old Jun 19, 2002 | 07:05 AM
sackdz's Avatar
Do you apply brake upon turn in?
Old Jun 19, 2002 | 09:14 AM
Chayse's Avatar
New User
I've heard of some people who will push the release button in and then drill a small hole through the handle and the button. This will let you insert a thin piece of metal such as a cotter pin. when the metal is in there, the button does not pop out and will not lock in the up position. You can just grab the handle, give it a quick yank and then let go. when you are finished your race, pull the pin out and the brake is back to normal. HTH
Old Jun 19, 2002 | 09:22 AM
Turtle's Avatar
Damn, I didn't know that Canada was flat...everywhere I have been has been mountainous as hell!
Atmosfear
10
Mar 2, 2012 05:55 AM
mighty_sol
Aug 28, 2006 03:09 PM
team703
26
Apr 8, 2004 09:42 AM
bruceski3
Aug 3, 2003 12:37 PM
r2x
10
Apr 10, 2002 05:47 AM
