Buyin GSR swapped CRX
Old Sep 27, 2007 | 02:50 PM
91lxstang's Avatar
Default Buyin GSR swapped CRX
Im buyin a gsr swapped 91 crx in alil and i have a few questions. First off what are people runnin with these? The one im buyin has a jdm gsr motor with a header, cat back, cai, and hi flow cat and it was tuned on a dyno with hondata. It also has other small stuff like a 255 fp, ls tranny with sum stage 3 clutch, short throw. Supposedly it only wieghs like 1800 pounds. Also its in good running condition. Seconf thing is, with a set of drag radials could it break mid 13's if its driven to potential? Thanks. By the way i own a foxbody mustang thats why my name is 91lxstang. Dont flame i like all cars.
Old Sep 27, 2007 | 03:52 PM
VegaS10's Avatar
The long geared LS tranny sucks unless you're going turbo.
I'd suggest the more tightly geared B16 tranny or maybe even a GSR tranny.
Old Sep 27, 2007 | 04:06 PM
STREETWERKZ's Avatar
Default Re: Buyin GSR swapped CRX (91lxstang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91lxstang &raquo;</TD></TR><TR><TD CLASS="quote"> First off what are people runnin with these? with a set of drag radials could it break mid 13's if its driven to potential? </TD></TR></TABLE>
*** NEW CRX / EF CIVIC FORUM RULES | TRIAL USER INFO ############## PLEASE READ IF YOU ARE NEW
2. Bench Racing/Can I win a race against "car x"/What will my car do in the quarter mile
you are new, and you obviously didnt read that thread.
the best thing you will learn on H-T is the search function. despite what a lot of newbs say, it works really well.
i suggest you take the car to the track and find out. come back and post the slip. that way other new people that use the search function could see what their potential could be.
Old Sep 27, 2007 | 05:11 PM
91lxstang's Avatar
Default Re: Buyin GSR swapped CRX (STREETWERKZ)
i did use the search forum and ive yet to find a timeslip or even sum1 stating what a gsr in a crx runs.... but i guess ill just have to guess...
also about the ls tranny, im not sure if thats what it is then if you say it has a higher gearset. I was told by the owner that it is a ls but is it normal to be at 4500-5000 rpm goin 85 on the highway in 5th gear with the ls tranny? cause ive test drove the car and thats what it runs.
Old Sep 27, 2007 | 05:14 PM
The_Undertaker's Avatar
75.168.105.221
Real cars are built not bought. Check for paperwork on the car. May be jacked.
VegaS10's Avatar
I'm not sure what rpms it will be at when at a given speed. But, I do know that the lower gears are longer. A B16 and a GSR have much shorter gears which help with acceleration.
Old Sep 27, 2007 | 05:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91lxstang &raquo;</TD></TR><TR><TD CLASS="quote">i did use the search</TD></TR></TABLE>
no, no you didnt.
Old Sep 27, 2007 | 05:33 PM
SIred91's Avatar
Rainman
Default Re: (1988hondacrxsiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 &raquo;</TD></TR><TR><TD CLASS="quote">Real cars are built not bought. Check for paperwork on the car. May be jacked.</TD></TR></TABLE>
STFU and GTFO troll.
Old Sep 27, 2007 | 05:35 PM
Pee Wee's Avatar
Default Re: (VegaS10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VegaS10 &raquo;</TD></TR><TR><TD CLASS="quote">The long geared LS tranny sucks even if you go turbo.
fixed
orly?
Old Sep 27, 2007 | 07:54 PM
B18c1vicrx's Avatar
actually i think there is a rpm calculater or something like that in the FAQ section
Old Sep 27, 2007 | 08:27 PM
Old School CRX Swap's Avatar
its problly not 1800 pounds unless its really gutted and as far as gearing goes my b16 tranny is at 4k and the speedo says about 70mph
Old Sep 28, 2007 | 10:03 AM
HT Chaplain's Avatar
Loved
Default Re: (Old School CRX Swap)
sounds like a b16 tranny
Old Aug 18, 2008 | 10:23 PM
EF_FEVER's Avatar
Default Re: (HT Chaplain)
Yeah I thinks it's a b16 tranny too. Mine S1 tranny is at 5000 rpms at 80 mph. Check the tranny number.
Old Aug 21, 2008 | 06:24 PM
azazello's Avatar
definitely sounds like some B16A tranny. in y1 i get 4.3k rpm at 80 mph, for reference
little B
May 4, 2007 07:49 PM
fredsintegra
Jan 3, 2007 04:22 PM
H.A.R.T B18C1EG6
Apr 27, 2006 09:53 PM
SacTownsGreatest39
Apr 20, 2005 01:00 PM
Outkast95LS
Nov 23, 2004 11:21 PM
