cracked rear tranny mount
Old Sep 27, 2007 | 02:44 PM
truplayaz24's Avatar
Default cracked rear tranny mount
cracked rear tranny mount on h22 could it be welded or do i have to change the casing or tranny>??
Old Sep 27, 2007 | 10:05 PM
MADMAX_zero's Avatar
Default Re: cracked rear tranny mount (truplayaz24)
So which is cracked, the mount, bracket, or the tranny casing?
Old Sep 28, 2007 | 01:42 PM
Default Re: cracked rear tranny mount (MADMAX_zero)
tranny casing
Old Sep 29, 2007 | 06:07 PM
bumping it up
Old Sep 30, 2007 | 11:10 AM
m R g S r's Avatar
you can weld it....thing is...you have to pull the tranny apart and clean the **** outta the inside of the housing where any oil came in conctact with it......
and you shold really drill each end of the crack so it doesn't spread more.
but if it is a known good tranny (aka no grinds, slides right into gear etc...) then it's probably worth it to pull it all apart and just have it TIG'ed by a good welder.
Old Oct 1, 2007 | 08:52 PM
Muckman's Avatar
Moderator in Chief
Default Re: cracked rear tranny mount (m R g S r)
I had the same thing happen on the driver side engine mount. Car got into an accident and broke the mount off the block. We welded the peice back on and never had a problem years later.
Old Oct 3, 2007 | 11:32 AM
Default Re: cracked rear tranny mount (Muckman)
SOME1 IN SUFFOLK NY NOW HOW TO WELD I GOT THE TRANNY OUT
Old Oct 13, 2007 | 02:25 PM
bump
Old Oct 15, 2007 | 05:54 PM
JDogg's Avatar
i have a tranny case ill sell you
Old Oct 15, 2007 | 06:26 PM
Default Re: cracked rear tranny mount (JDogg)
how much for case??
Old Oct 15, 2007 | 07:09 PM
JDogg's Avatar
$150 shipped
Old Oct 15, 2007 | 07:18 PM
...esteban's Avatar
Princess
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">$150 shipped</TD></TR></TABLE>
best solution...
Old Oct 15, 2007 | 09:34 PM
bigTom's Avatar
give the shop a call... i can probably weld it up for you depending on how bad it is.
Old Oct 16, 2007 | 05:57 PM
Default Re: cracked rear tranny mount (bigTom)
alrite ill give u guys a call thanks
Old Oct 17, 2007 | 10:02 AM
Bakeoff's Avatar
In the future you may want to speak English. No one wants to help out a dumbass that can't type.
ATrin
Apr 8, 2008 01:25 PM
integra3586
Feb 15, 2006 09:48 AM
mr_ek9
Jan 30, 2006 02:33 PM
Rob_Dog
Nov 13, 2004 10:44 PM
preluda92
Oct 27, 2003 06:13 AM
