44mm wastegate flanges??
Old Sep 27, 2007 | 09:52 AM
got wide's Avatar
Default 44mm wastegate flanges??
ok im building my first mani and its a divided t4 setup and i want to run two 44mm wastegates but was just looking on bmcrace's site and didnt see 44m, just 40 and 46. so can you guys help me out and explain to me which one to get, or if there is a 44mm flange available elsewhere that i should get??
Old Sep 27, 2007 | 11:30 AM
RCautoworks's Avatar
Default Re: 44mm wastegate flanges?? (got wide)
Full-race.com or atpturbo.com
Old Sep 27, 2007 | 12:47 PM
CoreyR's Avatar
Default Re: 44mm wastegate flanges?? (RCautoworks)
i get them from ATP. they are $20 each as opposed to $35 from full race.
Old Oct 2, 2007 | 08:54 AM
got wide's Avatar
Default Re: 44mm wastegate flanges?? (CoreyR)
i forgot to mention that i need mild steel. do any of you guys know if either one of these two companies will make a mild version or if any one else sells one already in mild.
Old Oct 2, 2007 | 12:04 PM
CoreyR's Avatar
why do they need to be mild steel?
Old Oct 2, 2007 | 04:49 PM
c jackson's Avatar
threes
you might not want to get a mild steel v band flange, it will rust and youll lose a good surface to seal with.
Old Oct 3, 2007 | 11:16 AM
Default Re: 44mm wastegate flanges?? (c jackson)
C Jack don't act like you know
Old Oct 4, 2007 | 09:33 AM
got wide's Avatar
will it be alright to weld the stainless ones to a mild steel header if so what filler rod do i need to use. also i was going to get the header ceramic powder coated to take care of the rust
Old Oct 4, 2007 | 02:33 PM
CoreyR's Avatar
its fine to weld stainless to mild. most manifold are stainless with mild flanges
you would use 309L for stainless to mild welds.
DaveF
Welding / Fabrication
21
May 4, 2009 01:23 PM
vtec_lude
Jul 2, 2007 02:23 PM
luv2drivecrx
Oct 23, 2005 08:03 AM
16vt
May 6, 2005 06:14 AM
FyReo3
Jul 9, 2004 08:27 PM
