GT35R CHRA = T25/28 CHRA?
I need to know if the GT35R CHRA is the Same size as a T25 CHRA (or is it the size of a t3/t4 chra. Ex: t3/t4 50trim stage 5). I believe this comes from the GT35R have a "Small shaft" similar to the T25/28 turbos.
if you're wondering about the length of the chra between the housings, it will be the same as the gt28 chras. t-series turbos are about 1/4-3/8" longer. as for the diameter of the shaft, i don't know. the shaft will be longer on the 35r than the t28's, because the wheels are bigger (depth wise, not just diameter).
es_squared
Jan 20, 2009 08:50 PM
