Want to go LST.. b18a or b18b better?
Old Sep 26, 2007 | 05:53 PM
Mixmasta's Avatar
Default Want to go LST.. b18a or b18b better?
i want to do an ls turbo, but i cant find a good deal on a b18b..
i had a shop tell me he could get me a full b18a swap for between 600 and 800..
so should i hold off and wait till i can find a newer one in my price range or is the b18a a good motor?
Old Sep 26, 2007 | 07:32 PM
doood's Avatar
been there done that
Default Re: Want to go LST.. b18a or b18b better? (Mixmasta)
they're the same thing basically. the important question is what car is this going into?
Old Sep 26, 2007 | 07:50 PM
crowder13's Avatar
92 civic and up = hydro tranny, 92 and below (b18a swap) = cable tranny. if u got a newer car get a b18b for simplicity for ur sake it'll swap right in. but there is no difference between the motors. minor if any.
Old Sep 26, 2007 | 08:04 PM
a1320honda's Avatar
Default Re: (crowder13)
the b18b (140hp) make 10 more hp than the b18a (130hp). the headwork on the b18b is a hair better. So id personly start with a b18b.
Old Sep 26, 2007 | 10:43 PM
LastGenEK's Avatar
Im not positive but, i think the b18a doesnt have a crank case breather( you know the little canister next to the oil filter)
Old Sep 26, 2007 | 11:07 PM
a1320honda's Avatar
Default Re: (LastGenEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LastGenEK &raquo;</TD></TR><TR><TD CLASS="quote">Im not positive but, i think the b18a doesnt have a crank case breather( you know the little canister next to the oil filter) </TD></TR></TABLE>
It does
Old Sep 27, 2007 | 02:25 AM
blackeg's Avatar
Default Re: (a1320honda)
b18b has very slightly better cam profile and intake manifold, hence the extra 12 hp.
also, theoretically a newer b18b will have less miles and less wear
Old Sep 27, 2007 | 04:20 AM
sneakysneaky's Avatar
A b18b top end is dirt cheap so go with wich ever is in the best
shape for the least $.
Old Sep 29, 2007 | 11:43 AM
Mixmasta's Avatar
ive also been hearing alot of shops telling me that obd2 is not very good, and that its going to be harder to swap an obd2 into an obd1 car..
Old Sep 29, 2007 | 12:27 PM
BOOSTEd2's Avatar
if your going LST then get an obd 1 motor. you'll be able to chip the ecu for it without getting a jumper harness
Old Sep 29, 2007 | 12:37 PM
Mixmasta's Avatar
and the obd1 motor is the b18a.. correct?
Old Sep 29, 2007 | 12:50 PM
a1320honda's Avatar
Default Re: (Mixmasta)
90-91 is obd0 b18a1, 92-93 is obd1 b18a1. 94-95 is obd1 b18b1, and 96+ is obd2 b18b1
Old Sep 29, 2007 | 01:02 PM
riceball777's Avatar
theres no differance between the 2 motors
blocks are the same
b18b has a better intake manifold and bigger cams
but the 2 motots are the same
Old Sep 29, 2007 | 04:25 PM
carter628's Avatar
so my best bet would be to try to find a 94 or 95 ls..
Old Sep 29, 2007 | 05:51 PM
BOOSTEd2's Avatar
Old Sep 30, 2007 | 02:52 PM
Mixmasta's Avatar
yeah but 92 and 93 are the older ls, b18a..
so if i could have my first choice it would be 94 or 95.
Old Sep 30, 2007 | 07:55 PM
BOOSTEd2's Avatar
either or would be better. just try to find one with good compression and low miles
89bluehatch
Feb 25, 2007 11:20 AM
TurboEM1
Nov 9, 2005 08:57 AM
effinnwackk
21
Jul 1, 2005 05:50 AM
tgintegra
Dec 20, 2003 01:21 PM
CRXSleeper
17
Sep 17, 2002 06:42 PM
