iacv hoses
Old Sep 26, 2007 | 04:20 PM
1kleenef's Avatar
Default iacv hoses
cant get the iacv vacuum hoses off and i really need to clean the iacv. how do i remove them without them ripping or getting damaged. Also where is the idle control screw on a dohc zc manifold thanks
Old Sep 26, 2007 | 05:21 PM
1kleenef's Avatar
Default Re: iacv hoses (1kleenef)
ne one plz help
Old Sep 29, 2007 | 01:45 PM
crxfreak1117's Avatar
there not vacumm lines there coolant lines and on mine there is alittle screw on the iacv that u can adjust idk about urs tho? and also there is a screw on the throttle body u can adjust but what is ur problem exactly?
Old Sep 29, 2007 | 05:53 PM
DAP91Si's Avatar
If you really need to get the hoses off, get a pair of pliers and gently grasp the end of the hoses. Turn the hose side to side to loosen it then use your hand to pull it off.
Old Sep 29, 2007 | 05:55 PM
The_Undertaker's Avatar
75.168.105.221
Once you remove the IACV check for condition because they usually go out.
Old Sep 30, 2007 | 05:29 AM
1kleenef's Avatar
Default Re: (1988hondacrxsiR1)
check the condition of what the coolant lines or the iacv?
Old Sep 30, 2007 | 05:31 AM
1kleenef's Avatar
Default Re: (1kleenef)
the problem is that when i start the car up if its cold it will idle at 2k. Then will go down to 1500 when its slightly warmed up. And if im in traffic it will bounce literally between 1500 and like 700 rpms. So im going to try and clean the iacv really well (with brake cleaner) and if that doesnt help ive heard that it might be a vacuum leak but how do i check for where one would be and how do i find it thanks.
Old Sep 30, 2007 | 10:09 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 &raquo;</TD></TR><TR><TD CLASS="quote">Once you remove the IACV check for condition because they usually go out. </TD></TR></TABLE>
STOP POSTING!!!!!! NOBODY LISTEN TO THIS IDIOT!!!!!
OP, you can just cut the hoses off if you need to and just get some new tubing at an auto parts store. In fact, you can clean the IACV with it still attached to the vehicle if it really comes down to it.
To adjust the idle, there is a screw on top of the TB for that. You may just try to turn down your idle speed and see if that helps, the DOHC ZC I last owned had an idle screw that would back itself out periodically.
Lastly, to check for vacuum leaks, spray carb cleaner around the IM, TB and vacuum lines, if the idle speed changes, you know where your leak is.
ohsnapzafingcu
Jun 16, 2011 06:07 AM
turboteg7
May 9, 2009 01:56 PM
Mikej425
Jun 26, 2008 04:18 PM
93formula
10
Aug 14, 2007 07:12 PM
BLUE EH3
May 17, 2005 03:10 PM
