Trans or clutch??
Old Sep 26, 2007 | 02:49 PM
Nicaraguense13's Avatar
Default Trans or clutch??
ok about a week ago i replaced the clutch on a 96 honda civic HB when i took out the old clutch the thing was so SMOOTH no grip so i replaced it a used one with alot more grip.Well I was replacing the clutch because of the sudden noise that occurs as soon as i release the clutch peddle like a piece of metal is being tossed around. Well doing the obvious i replaced the THROWout bearing the clutch not the pp or the flywheel they looked fine. Is this a bad trans???????? it juss rattles like crazy as soon as the pedal is released on neutral 1 2 3 etc any ideas?
Old Sep 26, 2007 | 02:57 PM
Murk 'EM's Avatar
Default Re: Trans or clutch?? (Nicaraguense13)
if your not in gear and it does it its not gonna be the trans.. its probably your pressure plate
Old Sep 26, 2007 | 03:03 PM
Default Re: Trans or clutch?? (95_acc0rd)
ok the pp was ok all the teeth are their juss a big line around it where the Throwout bearing hits it...... but from what i saw it was complete
Old Sep 26, 2007 | 03:22 PM
1992Si's Avatar
Pressure plates don't have teeth. They have figures.
IMO a spring fell out of the clutch disc.
Old Sep 26, 2007 | 03:24 PM
Default Re: (1992Si)
well it was doing this before i put the other one in so i dont think its the spring well the figures have a line thanks for the correction
Old Sep 26, 2007 | 08:36 PM
Murk 'EM's Avatar
Default Re: (Nicaraguense13)
the lines just ware from the TB.. if its a groove then thats another story
Old Sep 30, 2007 | 07:53 AM
Default Re: (95_acc0rd)
well im gonan check out this weekend im about 2 juss get another trans since its only 50 bucks
MiNeSEK
19
May 11, 2013 12:05 AM
ludelvr
Sep 28, 2003 11:02 AM
JONBLAZE55555
Jul 11, 2003 11:32 PM
integra81
Mar 10, 2002 12:17 AM
