Car rev's itself while air conditonor is on??? Plus more
Old Sep 26, 2007 | 11:59 AM
Acidcrakker's Avatar
Default Car rev's itself while air conditonor is on??? Plus more
Today after I got done playing with my car I noticed while driving home, that with the air conditionr on the car would rev itself up to 2k, then drop to .5k continusly in neutral. Strange. When I finally got home, I popped the hood to see what the problem was, and it wouldnt do it. Now I have the heat shield off the stock headers, and the coolant tank is bone dry as well.
All these things are very strange. Do you guys think its possible that with the heat shield off the coolant evaporated due to the heat. Or the more likly there is a coolant leak somewhere? Its a realtivly new radiator.
As for the car reving by itself thats still a mystery, mabey the altenator is going bad???
IDK
Old Sep 26, 2007 | 12:30 PM
GraphiteMW's Avatar
Default Re: Car rev's itself while air conditonor is on??? Plus more (acidcrakker)
Check your vacuum linesu
Old Sep 26, 2007 | 12:36 PM
Default Re: Car rev's itself while air conditonor is on??? Plus more (GraphiteMW)
I have also put on another new air intake. There was a little line on the intake manifold that I blocked up to as well. Should I unblock that and let it suck in unfiltered air?
Old Sep 26, 2007 | 03:20 PM
JasonST's Avatar
What line did u block off, is it the return air line going from the valve cover to the intake?
Old Sep 26, 2007 | 03:29 PM
Default Re: Car rev's itself while air conditonor is on??? Plus more (JasonST)
No. Its the tiny little hose that runs from the intake manifold to the air intake pipe.
I have since then removed the plug that I stuck on there and have not had it happen since then.
Old Sep 26, 2007 | 07:10 PM
prelude_93vtec's Avatar
ya i wouldnt mess around with the vaacum. lol when i took out my IM i forgot to atach the coolant returbn hose and when i backed up i saw a pile of coolant so that could be your collant missing problem
Old Sep 26, 2007 | 07:25 PM
Default Re: Car rev's itself while air conditonor is on??? Plus more (prelude_93vtec)
I have no clue about the coolant. Im hoping it doesnt have a leak. I never bother to check it since Ive had the car, its been about 2 months since I got it, Im hoping it just dried up. But I will be keeping an Eye on it.
Old Sep 27, 2007 | 04:45 AM
flyrod's Avatar
https://honda-tech.com/zerothread?id=1979500
Wrona
Nov 6, 2011 02:26 PM
kakahoya
Feb 27, 2008 07:53 PM
vic_houston
Jan 3, 2008 08:59 PM
bigizsosexy
May 14, 2006 07:34 PM
Conechaser
Oct 2, 2001 01:00 PM
