problem with my gsr on my 99 civic
Old Sep 26, 2007 | 05:04 AM
IMPORT_IMAGE's Avatar
Default problem with my gsr on my 99 civic
i have a 1999 civic with a gsr and it dont seem to run right its kind of slow taking off could it be the v-tech or wut
if so can some one let me know how to wire up the v-tech
Old Sep 26, 2007 | 05:11 AM
HondamanXxX's Avatar
GO GIANTS!
Default Re: problem with my gsr on my 99 civic (IMPORT_IMAGE)
It's hard to help out when there is little information. Did you do this swap or did you buy the car with the swap? Secondly, Vtec, not Vtech, kicks in at 4,500 rpm.
Modified by HondamanXxX at 11:09 AM 9/26/2007
Old Sep 26, 2007 | 05:18 AM
Default Re: problem with my gsr on my 99 civic (HondamanXxX)
no i got the car like that and it takes long to speed up the car chokes
Old Sep 26, 2007 | 05:19 AM
GO GIANTS!
It could be a million things. Idk where to start
Old Sep 26, 2007 | 05:24 AM
GO GIANTS!
Are you sure it is a GSR motor? Are your secondiarys working? What ECU are you running?
Risks of buying a car with swap done already
Old Sep 26, 2007 | 05:48 AM
the car was running fine at first but the other day it starter to expletive up the car lost alot of power (could it be the timing belt????)
Old Sep 26, 2007 | 07:05 AM
gibsanez's Avatar
What CEL's do you have?
Old Sep 26, 2007 | 08:14 AM
Default Re: problem with my gsr on my 99 civic (gibsanez)
wut cel's
Old Sep 26, 2007 | 08:23 AM
gibsanez's Avatar
Do you have a check engine light?
Old Sep 26, 2007 | 08:25 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPORT_IMAGE &raquo;</TD></TR><TR><TD CLASS="quote">wut cel's </TD></TR></TABLE>
Check Engine Light = CEL.
What codes is your car throwing if any? Have them scanned. Autozone does it for free.
Your problem could be 1589816876851698768168765167987 billion things.
Need more information.
VTEC kicks in at 4500rpm (GSR ECU). Secondaries open at 6k (if they're working).
Old Sep 26, 2007 | 08:54 AM
mach0's Avatar
^^^i was about to type the same thing.till i read it...could be alot...good luck..u def need to provide more info about the problem..
Old Sep 26, 2007 | 09:09 AM
Default Re: (mach0)
**** i could of give more info but i dont know **** about this car
Old Sep 26, 2007 | 10:56 AM
gibsanez's Avatar
Default Re: (IMPORT_IMAGE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPORT_IMAGE &raquo;</TD></TR><TR><TD CLASS="quote">**** i could of give more info but i dont know **** about this car </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">What CEL's do you have?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a check engine light?</TD></TR></TABLE>
Old Sep 27, 2007 | 05:27 AM
Default Re: (gibsanez)
yes it has the CEL on
Old Sep 27, 2007 | 05:34 AM
GO GIANTS!
Follow these instructions https://honda-tech.com/zerothread/1901557
Old Sep 27, 2007 | 06:12 PM
B serious's Avatar
Default Re: (HondamanXxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">Follow these instructions https://honda-tech.com/zerothread/1901557</TD></TR></TABLE>
or the easy way:
TAKE IT TO AUTOZONE. THEY CHECK CELS FOR FREE. THEY WILL GIVE YOU THE CODE. DECIPHER THE CODE USING THE LINK ABOVE.
go-fast_integra
11
Oct 21, 2010 04:35 PM
krazyEG
Engine Management and Tuning
Sep 11, 2008 09:17 PM
Binx18
21
Jul 25, 2007 04:00 PM
HondAJunkie92
May 3, 2005 07:36 AM
