bent valvue/ skipped tooth question,
Old Sep 25, 2007 | 09:34 PM
P12 EG6's Avatar
Default bent valvue/ skipped tooth question,
ok my friend just put is gsr togeather and idint tighten the timing belt properly and he started the motor for 10 seconds and the timing belt skipped a couple of teeth in the cam gears it kept running untile he turned it off... and tried to restart ....wouldnt start... so her checked the timin and it was off a by like 5 teeth... so fixed it right and it idols fine... do you think it could have bent any of the valvues or internal parts???
Old Sep 25, 2007 | 09:40 PM
stock_honda_coupe's Avatar
Default Re: bent valvue/ skipped tooth question, (P12 EG6)
Not sure about GSR engines, but on most engines you can get away with that. Espesially if it run just fine now.
Old Sep 25, 2007 | 09:42 PM
P12 EG6's Avatar
Default Re: bent valvue/ skipped tooth question, (stock_honda_coupe)
sick... hell be stoaked... he said it made a weird squeek noise thought... he couldnt tell where but he said it sounded like metal on metal... if it had all bent valvues wouldnt it idol like ****.....
Old Sep 25, 2007 | 10:11 PM
RiceOrRocket's Avatar
yes, since air isn't entering/leaving at the same time. Do a comp. check do be sure.
Old Sep 25, 2007 | 10:14 PM
drtysohc's Avatar
Uh...that's not good. Do a compression test.
sd619jef9
18
Aug 25, 2012 10:35 AM
wakabakev1
Aug 4, 2011 08:13 PM
erikiksaz1
Apr 13, 2009 05:33 PM
918-Hatch
20
Jan 23, 2007 03:39 PM
raylude
Apr 6, 2005 07:49 PM
