h22a oil port question?
Old Sep 25, 2007 | 06:08 PM
trrbl1bmx's Avatar
Default h22a oil port question?
On the H22a right above the thermostat housing on the cylinder head there are 2 allen head screws, One is on the rear of the engine (firewall) and one is on the right (passenger side) My question is the smaller on with 1/8NPT threads, would this be sufficent for an electrical VDO oil pressure sending unit. I have searched and see nothing. Thanks.
Old Sep 25, 2007 | 06:11 PM
117's Avatar
117
Yes, that's where I have my Defi oil pressure gauge plumbed. It's not 1/8" NPT. It's 1/8" BSPT, which is slightly different.
Old Sep 25, 2007 | 06:15 PM
98vtec's Avatar
moderator emeritus
Default Re: h22a oil port question? (p00n)
that would only be monitoring oil pressure in the head tho. Not exactly the most sufficent placement, imo.
Old Sep 25, 2007 | 06:30 PM
trrbl1bmx's Avatar
Since oil pressure is determined by the main bearing clearence, I am willing to bet placement would more than sufficient, I just wanted peice of mind that someone else has put their sending unit there. After all I would imagine that's where a Honda Tech would test for oil pressure rather than pulling the pressure switch off the back of the engine. Thanks for the reply 117 and the info about the thread pitch!!
Old Sep 26, 2007 | 02:38 AM
117's Avatar
117
Default Re: h22a oil port question? (Evil.98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil.98vtec &raquo;</TD></TR><TR><TD CLASS="quote">that would only be monitoring oil pressure in the head tho. Not exactly the most sufficent placement, imo.</TD></TR></TABLE>
That port is directly fed from the outlet of the oil filter. If you're not reading pressure at that port, you don't have pressure in the bottom end either.
Old Sep 26, 2007 | 02:39 AM
117's Avatar
117
Default Re: (p00n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p00n &raquo;</TD></TR><TR><TD CLASS="quote">Since oil pressure is determined by the main bearing clearence, I am willing to bet placement would more than sufficient, I just wanted peice of mind that someone else has put their sending unit there. </TD></TR></TABLE>
Oil pressure is determined by more than the main bearing clearance.
Old Sep 26, 2007 | 06:07 PM
trrbl1bmx's Avatar
Yes, but the main factor to oil pressure is your main bearing clearences. Oil filter, rod bearings, oil squirters, ect. all play a role.
Old Sep 26, 2007 | 06:27 PM
117's Avatar
117
EDIT: nevermind....
Old Sep 26, 2007 | 06:37 PM
alterdcreations's Avatar
Default Re: (p00n)
that's a nice peice of POOn
Old Sep 27, 2007 | 06:51 AM
mgags7's Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">EDIT: nevermind....</TD></TR></TABLE>
lol
discretion
Old Sep 28, 2007 | 02:31 PM
trrbl1bmx's Avatar
Default Re: (mgags7)
117 I am not trying to argue with you. I have been building engines for close to a year for hooters cup,arca,and some busch stuff. I know where oil pressure comes from. Aside this, thanks for the good info on the port.
Old Sep 28, 2007 | 03:25 PM
117's Avatar
117
Who are you building engines for?
88h22_CRX
Oct 31, 2014 05:41 AM
pcguy760
Jun 21, 2011 12:01 PM
delslowtofast
Oct 15, 2007 09:27 PM
