Suspension & Brakes Theory, alignment, spring rates....
washer trick, couldnt find grade 10 bolts...
Old Sep 25, 2007 | 12:14 PM
jredhonn's Avatar
Default washer trick, couldnt find grade 10 bolts...
try to do the washer trick on my car, went to all different hardware stores in my area, the hardest bolt i can find is grade 8.8. ( little bit harder than grade 8).
do you guys think grade 8.8 will be safe?
Old Sep 25, 2007 | 03:19 PM
117's Avatar
117
A grade 8.8 metric bolt is roughly equivalent to a grade 5 SAE bolt. You'll want a metric bolt that's at least grade 10.9 (roughly equivalent to grade 8 SAE bolt). I would not use a grade 8.8 bolt on suspension pieces.
http://www.americanfastener.co...l.asp
http://www.k-tbolt.com/bolt_chart.html
You should be able to find them here: http://www.mcmaster.com
Todd00
10
Dec 15, 2014 08:05 PM
Bense
19
May 12, 2007 10:15 AM
BoostinEJ1
41
Apr 16, 2006 01:18 PM
Sleepy86o
Nov 10, 2005 03:52 AM
smoke3
Jul 2, 2004 04:40 PM
