compression test done (LOOK)
Ok so I did a compression test on my 89 civic 1.5 dx 5 speed. The results are as follows..#1 180,#2 181,#3 181, #4 180. ..Do these numbers sound normal for this motor. All stock no modifications. The reason why I did a comp check is because I am loosing oil. I am thinking its the valve guides on the head but I am not sure what the compression is suppose to be at on this motor. Any help would be appreciated.
that is about right i did mine and they were 190
across the board
as long as there consistant youre fine
if the valve seals are going you would be burning the oil meaning smoke from your exhaust
i would put yor car on a lift and look on the back side of the block for any driping
or under the timing cover
across the board
It does leak a little bit. I noticed that the exaust is black. The plugs all came out clean except for #2. It was not oil soaked but it was not as clean as the rest.
Do you think it is the head(valve guides) or should I just get another motor?
blackeg
Mar 28, 2005 06:10 AM
jdm169
Mar 7, 2003 09:28 AM
not so civic
Dec 30, 2002 03:29 PM
