lost 2.5 quarts of oil in a weekend
Old Sep 24, 2007 | 05:19 PM
94allmotor's Avatar
Default lost 2.5 quarts of oil in a weekend
ok i got a 00 civic with a gsr swap. this weekend i was driving to NY from Boston total miles back and forth about about 550 miles i checked my oil this morning and i was missing 2.5 quarts. another thing is my car is smoking so is it the rings going bad? headgasket? or other problems?
Old Sep 24, 2007 | 05:23 PM
russlan44's Avatar
Default Re: lost 2.5 quarts of oil in a weekend (94allmotor)
if ur burning oil ur rings might be bad, and what color is the smoke in back of your car, also do u have any leak spots
drtysohc's Avatar
It could be a number of things.
Have you done a compression and/or leakdown test?
Old Sep 24, 2007 | 08:24 PM
civiceg94's Avatar
a compression test and a wet compression test could help you out alot. or a vacuum test. it could be a couple of thing valve seal, piston rings, head gasket. thats why its good to do one of the test before you start replacing parts without knowing what was it.
Old Sep 24, 2007 | 08:28 PM
95sloweg's Avatar
Default Re: (civiceg94)
I lost 2.5 quarts since my last oil change, which was in late July, and there is no smoke coming out of the exhaust. there arent any leaks where ever i park.
Old Sep 24, 2007 | 08:45 PM
94allmotor's Avatar
last oil change was 2 weeks ago the smoke is white but it doesnt smokemalot like when a headgaskets blown..how do i do a comp. test
Old Sep 24, 2007 | 08:48 PM
95sloweg's Avatar
Default Re: (94allmotor)
white smoke is definately(spelling?) not oil burning.
Old Sep 24, 2007 | 08:57 PM
posHonda's Avatar
are you sure you dont have any leaks?? if youre not leaking and lost 2.5qts than it has to be burning.
Old Sep 24, 2007 | 09:01 PM
95sloweg's Avatar
Default Re: (iVteC_PoWeR)
that was me talking about no leak spots. He never answered that yet.
Old Sep 25, 2007 | 10:20 AM
94allmotor's Avatar
their some oil stains but tom. on my day off im gonna clean the head and part of the block to check for leaks. im pretty sure their are leaks but that wont make me lose 2.5 quarts over the weekend the leaks are very minimal
Old Sep 25, 2007 | 10:22 AM
jdm91CrxSi's Avatar
might be vtec..
seems to burn some oil
Old Sep 25, 2007 | 11:37 AM
russlan44's Avatar
Default Re: (jdm91CrxSi)
have you been using your vtec a lot
Old Sep 25, 2007 | 11:59 AM
jit01's Avatar
Default Re: (russlan44)
if i go into vtec a lot that happens to me. I have a b16 motor check your oil level after you go into vtec.
Old Sep 25, 2007 | 03:49 PM
ricefourlife's Avatar
Most likely it is v-tec I think it is safe to say all Honda's use a little oil
Old Sep 25, 2007 | 04:53 PM
94allmotor's Avatar
this is my forth vtec engine i had 2 gsr's before and a tsx now..i dont think hitting vtec will burn 2.5 quarts of oil..
Old Sep 25, 2007 | 05:31 PM
drtysohc's Avatar
do a compression check!
8YourV8
Dec 28, 2006 01:05 PM
Fat Chick Magnet
Nov 24, 2006 02:50 PM
Tony_EM1
May 26, 2005 10:34 PM
Old_Honda
Apr 5, 2005 08:25 PM
ILLA_00LS
Jul 22, 2003 12:06 PM
