clutch problem. Need help
I have a 94 accord ex 5 speed. I've been adding alot of clutch fluid. Everyday it goes down and I have to fill it up. Sometimes there is no clutch fluide at all and I have to fill it up. I fill it up once a day. Please help. What do you guys think it is?
It must be leaking out somewhere. Find out where...
Master cylinder can leak alongside the pushrod, then it soaks into the padding underneath the carpet (look under the pedals).
The clutch master can also leak in the engine compartment but less likely. A leak there might be the rubber tube from the fluid reservoir down to the actual clutch master cylinder. That would be lucky, 'cause it's easy to fix.
Slave cylinder is exposed, next to the radiator fans. Look for a puddle of fluid on the ground.
Another possibility is the tubing. Look for a puddle...
Many people say if you have to replace the master you better replace the slave because it's gonna fail in another few months.
