Turbo not working right
Old Sep 24, 2007 | 08:28 AM
GibsonNO!'s Avatar
Default Turbo not working right
My 5th gen base prelude is not working, but not properly. I just got finished putting the turbo kit on and it makes boost but the car gets laggy and stutters once the turbo is making max boost which is around 4k and suggestions.
Old Sep 24, 2007 | 08:37 AM
98vtec's Avatar
moderator emeritus
Default Re: Turbo not working right (GibsonNO!)
are you tuned?
Old Sep 24, 2007 | 08:58 AM
Hawkze_2.3's Avatar
Default Re: Turbo not working right (Evil.98vtec)
Yeah, it sounds like you need to do some tuning...just bolting on a turbo kit has never worked.
Old Sep 24, 2007 | 09:30 AM
93SiPrelude's Avatar
You cant just bolt on a turbo and not tune it. That puts too much air into the motor and not enough fuel. Stop driving it and get it tuned before you blow your motor becuase its running to hot.
Old Sep 24, 2007 | 10:16 AM
GibsonNO!'s Avatar
The car has an FMU for the fuel delievery for now until the computer gets sent off to get reprogrammed. I have an 94 integra ls with basically the same setup and and it ran normally after the installiation.
Old Sep 24, 2007 | 10:18 AM
nonvteclude's Avatar
no no no no. you have to tune it. preludes and integras are not the same car. stop driving the lude with the fmu. get it tuned on a dyno with a compitant tuner.
Old Sep 24, 2007 | 10:22 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GibsonNO! &raquo;</TD></TR><TR><TD CLASS="quote">The car has an FMU for the fuel delievery for now until the computer gets sent off to get reprogrammed. I have an 94 integra ls with basically the same setup and and it ran normally after the installiation.</TD></TR></TABLE>
what plug gap are you running?
the car will run fine on the FMU for now so long as its working correctly. But i would suggest getting the ecu and having it tuned ASAP. STAY OUT OF BOOST. But you cant determine that without a wideband.
Old Sep 24, 2007 | 11:05 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GibsonNO! &raquo;</TD></TR><TR><TD CLASS="quote">The car has an FMU </TD></TR></TABLE>
Problem located.
Old Sep 24, 2007 | 12:08 PM
jdmbreed's Avatar
Default Re: Turbo not working right (Hawkze_2.3)
whats up man are u the guy i talked too at Nopi Nationals??? and suggested to come to this site for help???
Old Sep 24, 2007 | 02:29 PM
vietdragontekx's Avatar
Default Re: Turbo not working right (jdmbreed)
tune is the key bro, FMU = crap, make you u gap your spark plug for turbo..i recommend the NGK v power 1 step colder..
u can't compare a b series to a H series..
wouldn't recommend you taking ur motor up that high at boost without tune..
Old Sep 24, 2007 | 04:09 PM
preludefien
Guest
Posts: n/a
Default Re: Turbo not working right (vietdragontekx)
you will have to get it tuned for like the 6th time. cant tune on the p13 though so yea i wouldnt boost unless you want to blow some **** up.
Old Sep 24, 2007 | 04:17 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil.98vtec &raquo;</TD></TR><TR><TD CLASS="quote">are you tuned?</TD></TR></TABLE>
are you tuned?
Old Sep 24, 2007 | 06:41 PM
98vtec's Avatar
moderator emeritus
Default Re: Turbo not working right (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
of course i am.
i want to know the plug gap. The turbo could be blowing out the spark.
Old Sep 25, 2007 | 01:57 AM
Doostur's Avatar
https://honda-tech.com/zeroforum/16
Old Sep 25, 2007 | 05:14 AM
PrecisionH23a's Avatar
What are you running for a map sensor? Missing link? Bleeder valves?
What are you plugs gapped at? Are you running a colder plug?
FMU = H22 Death
Old Sep 25, 2007 | 02:37 PM
GibsonNO!'s Avatar
Default Re: Turbo not working right (PrecisionH23a)
I have stock plugs in it now I have new plugs gapped to .30 and my computer was just removed and sent off to be reprogrammed. Once its back the FMU will be removed.
Old Sep 25, 2007 | 02:57 PM
98vtec's Avatar
moderator emeritus
put the new plugs in.
Old Sep 25, 2007 | 03:05 PM
switched_in_your_eye's Avatar
"My 5th gen base prelude is not working, but not properly. I just got finished putting the turbo kit on and it makes boost but the car gets laggy and stutters once the turbo is making max boost which is around 4k and suggestions. "
What it's not just like Need For Speed Underground where you just put it on and all of the sudden the cars faster. That's weird dude.
Old Sep 25, 2007 | 03:15 PM
98vtec's Avatar
moderator emeritus
Default Re: Turbo not working right (switched_in_your_eye)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by switched_in_your_eye &raquo;</TD></TR><TR><TD CLASS="quote">"My 5th gen base prelude is not working, but not properly. I just got finished putting the turbo kit on and it makes boost but the car gets laggy and stutters once the turbo is making max boost which is around 4k and suggestions. "
apparently he understands this already but expected it to atleast run properly with the FMU.
my bet is on the spark plugs. stock plugs have too much gap for turbo.
Old Sep 25, 2007 | 05:08 PM
GibsonNO!'s Avatar
Well thanks for the help just gotta wait and see when my computer gets back.
Old Sep 25, 2007 | 05:56 PM
98vtec's Avatar
moderator emeritus
put the plugs in before the computer gets back.
Old Sep 25, 2007 | 06:51 PM
GibsonNO!'s Avatar
Just throwin this question out there Ive heard several people say that your block needs to be resleeved to install forged pistons and others say that it is not required but other work needs to be done.
Old Sep 25, 2007 | 06:53 PM
98vtec's Avatar
moderator emeritus
read the faq, please.
https://honda-tech.com/zerothread?id=416069
Old Sep 27, 2007 | 04:40 PM
GibsonNO!'s Avatar
Do you know of a way to test an FMU to make sure it is working properly. Right now it is not installed on the car.
WorkedDelSol
Jun 28, 2006 10:22 AM
hellsyea2020
Jun 12, 2005 07:17 PM
civic909
Sep 22, 2004 12:29 PM
sparq
Dec 18, 2002 01:46 PM
FrostyGSR
Feb 15, 2002 12:01 PM
