faint misfire?
was doing a 3rd gear pull and when i let off and shifted into 5th i noticed a slight misfire. i took the plugs out they were a little black so i put new ones in and gapped them to .027 7e, but it still had the misfire. you can only tell it has a misfire at low engine speeds, cruising on the interstate you cant tell it has a misfire. only thing i noticed different is it has sort of a hesitation when you try to start it but it fires right up, any suggestions would be appreciated. the motor is a stock b16 t3/t4 10 psi crome pro. thanks guys
the ignition system components are old ie... the distributur and the components inside are a 91 integra ls. what should i gap the plugs down to? are the components in my distributor ie... ignition coil and ignitor compatible with a jdm obd0 b16 distributor components?
hyabusa hunter
21
Oct 19, 2010 01:38 PM
nonvtec92
Aug 26, 2010 01:46 PM
jchung
26
Mar 16, 2007 11:24 PM
1baddcivicsi
Oct 6, 2006 07:35 PM
