Car is down!! Need help please!!
Old Sep 23, 2007 | 08:45 PM
sohchatch89's Avatar
Default Car is down!! Need help please!!
Alright here's what happen with my 90' civic hatch. I was driving around for about 5-10 mins and then all of a sudden my car just shuts down my brakes lock and everything and i try starting it again and it started for about 5 seconds then it just shutted off again. So i pulled over to the side tried starting it again nothing happend no crank no nothing. And before i drove around there was squeking noise coming from the belt area. So please if anyone out there knows or thinks they know what could be the problem would be helpfull. NEED HELP ASAP!! Please and Thanks...
Old Sep 23, 2007 | 08:47 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Car is down!! Need help please!! (sohchatch89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohchatch89 &raquo;</TD></TR><TR><TD CLASS="quote">Alright here's what happen with my 90' civic hatch. I was driving around for about 5-10 mins and then all of a sudden my car just shuts down my brakes lock and everything and i try starting it again and it started for about 5 seconds then it just shutted off again. So i pulled over to the side tried starting it again nothing happend no crank no nothing. And before i drove around there was squeking noise coming from the belt area. So please if anyone out there knows or thinks they know what could be the problem would be helpfull. NEED HELP ASAP!! Please and Thanks...</TD></TR></TABLE> Did you inspect the belt?
If the last thing you heard was it making a racket, it probbly busted on you.
Old Sep 23, 2007 | 08:56 PM
SIred91's Avatar
Rainman
Default Re: Car is down!! Need help please!! (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote"> Did you inspect the belt?
If the last thing you heard was it making a racket, it probbly busted on you.</TD></TR></TABLE>
x2.......How do your brakes and all just lock up?
Old Sep 23, 2007 | 08:59 PM
yes i did inspect the belt and the belt was loose on the left side and on the right side it was pretty stiff.. so i dont really know wat is wrong wit it.. and no it wasnt making a racket it was just squeking from the belt area.
Old Sep 24, 2007 | 10:59 AM
jakscivic's Avatar
erm, did your timing belt snap?
Old Sep 24, 2007 | 01:14 PM
nope the timing belt is still good i believe.
Old Sep 24, 2007 | 01:29 PM
mike-y's Avatar
Default Re: (sohchatch89)
did you inspect the belt carefully? You could have stripped some teeth, which would kill the motor, but the belt would still look intact. I've seen this happen on a couple of cars.
Old Sep 25, 2007 | 11:23 PM
jakscivic's Avatar
yeah, um, if you "believe" the timing belt is still there, then I would check that if I were you. Thats a pretty important piece of the motor. And yes, the belt could have stripped, or even jumped a couple teeth.
Old Sep 26, 2007 | 04:52 PM
konka's Avatar
Default Re: (jakscivic)
not only that if the belt jumped and the cam turned u coulda bent a valve. but like everyone else said check the belt. Id replace it altogether. set the cam with the up mark on the sproket pointing straight up then bring #1 piston to tdc(top dead center). put new belt on and tighten the tensionor not to tight or u could snap the cam and itll make a really annoying humming sound. thats my thoughts hope it helps. ask if u need nething else.
CRX30436
10
Jan 7, 2008 03:29 PM
oxSLEEPERxo
Nov 29, 2005 08:17 PM
dumestickilla4life
12
Jun 4, 2005 12:52 PM
BoostinEJ1
11
Dec 8, 2003 04:59 PM
CR-V
49
Nov 5, 2003 10:52 PM
