help: Hatch is squeling like a pig
I've searched and looked at a lot of threads about this problem and it seems that a common answer is the alternator belt. But mine isnt a constant squeal or anything, its random, at all different speeds, rpm's, and what not. It never does it at start up. It almost sounds like its coming from the far right but i dont know. Any help would be cool, thanks.
Modified by JdmEGHatch6 at 7:16 PM 12/5/2003
The A/C is not on when it does this, its a bit too cold here for that right now. But I have yet to check the belts to see if they are worn or loose. I suppose I should do that asap, I just wanted to see what everyone thought. Thanks.
Re: (JdmEGHatch6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEGHatch6 »</TD></TR><TR><TD CLASS="quote">The A/C is not on when it does this, its a bit too cold here for that right now. But I have yet to check the belts to see if they are worn or loose. I suppose I should do that asap, I just wanted to see what everyone thought. Thanks.</TD></TR></TABLE>
Yeah, my initial guess would be to check the belts and make sure they're tight.
Mike
Mike
Re: help: Hatch is squeling like a pig (JdmEGHatch6)
atleast we arent trying to replace your cam seal pointlessly again jim...sorry for snappin that bolt in ur head to...we sorted it all out though...i still think u just have a birds nest in there...just put some bird sead near ur headlight...they will make there way out soon enough...as soon as there wings get stronger..lol...nah just kidden...im sure its no big problem...prob just a stupid lil belt...well look at that **** later
I may have a birds nest under my hood but atleast i dont sound like a ******* girl from those 1-800 sex numbers, not that I call them or anything! haha jp.
ok ive come to think that it may be something with my brakes, my belts are fine. the sound stops the second i put my foot on the brake... any ideas?
TTT
TTT
Re: (JdmEGHatch6)
the noise is probably your brake pads vibrating,if the pads are not worn to the point they need changed just pull them out clean them with brake cleaner(backside only) then apply some disc brake quiet made by permatex,several thin coats will do.clean your caliper off to cause the d/b quiet will become a sticky barrier that will help keep them badboys quiet.this may not completely stop all noise but it will reduce it dramatically.you should also do this when putting on new brakes!
Tippyman
16
06-05-2006 07:16 AM
esoterEK..
12-13-2004 09:47 AM
