need help on putting on fender and hood...
Old Sep 23, 2007 | 08:08 PM
ShinotakuX's Avatar
Default need help on putting on fender and hood...
recently i got into an accident and damaged my RH side fender and hood, and i purchased an oem painted fender and oem style carbon fiber hood, but dont know how to take off the fender, pls someone guide me through it with pictures or directions, as for the hood, i thank i can figure it out its just to bolts that i have to take out right? thanks in advance.
Old Sep 23, 2007 | 08:18 PM
EK_B's Avatar
For the fender, you have to take the side skirts out exposing two bolts I think. Pop the hood there should be three bolts, take the bumper off and there are like two bolts around the headlight area.
You have to take out the fenderlining clips also. And there is one where you have to open the door to reach a bolt, all bolts need a 10mm socket.
Old Sep 23, 2007 | 08:26 PM
ShinotakuX's Avatar
Default Re: need help on putting on fender and hood... (ShinotakuX)
how do i take off the sideskirts on the fender?
Old Sep 23, 2007 | 08:55 PM
EK_B's Avatar
There are 2 or 3 screws connecting the fender lining to it, you might have to take off the tire to get to them. After that, you push the side skirt towards the car I believe and it should fall out.
Old Sep 23, 2007 | 09:11 PM
ShinotakuX's Avatar
there seems to be some screws at the bottom, near the sideskirt part, its stuck there but everything else is out, do i have to take off the sideskirts to get it out or there are some hidden screws or something?
Old Sep 23, 2007 | 09:18 PM
Ritchie's Avatar
You would need to take off the sideskirt to get to the last bolt of the fender. The screws you were talking about, are you talking about screws under the sideskirt or screws around the fender keeping the plastic covering intact?
Old Sep 23, 2007 | 09:24 PM
ShinotakuX's Avatar
Default Re: need help on putting on fender and hood... (Ritchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ritchie &raquo;</TD></TR><TR><TD CLASS="quote">You would need to take off the sideskirt to get to the last bolt of the fender. The screws you were talking about, are you talking about screws under the sideskirt or screws around the fender keeping the plastic covering intact?</TD></TR></TABLE>
im talking about the screws around the fender keeping the plastic covering intact, i dont have to take that out right? the fender will be out after i take the sideskirts out and remove the bolts/screws right?
Old Sep 23, 2007 | 09:29 PM
Ritchie's Avatar
Well since you are changing to a new fender, you need to take those screws off around the fender. There is one bolt on the fender after you take your sideskirt off and one more bolt on the top corner of the fender when you open the door.
Old Sep 24, 2007 | 06:51 AM
EK_B's Avatar
Did you just completely ignored my post?
Old Sep 24, 2007 | 07:03 AM
instrument's Avatar
there is a walk through to replacing a fender in the faq.
wtf.
m1ndless
Jan 8, 2008 07:14 AM
aka red
Aug 8, 2007 05:45 PM
dc2long
Apr 10, 2007 07:44 PM
litterbox
Sep 24, 2004 11:03 AM
