bolts from engine side motor mount to engine
Old Sep 23, 2007 | 01:59 PM
Del Sol on Steroids's Avatar
Default bolts from engine side motor mount to engine
I need to order the bolts that go from the driver side engine motor mount to the motor. I checked through slhondaparts.com but i can't see them there, does anyone know what the bolt size is?
Old Dec 4, 2007 | 08:43 PM
Locrien's Avatar
Default Re: bolts from engine side motor mount to engine (Del Sol on Steroids)
Bump for an answer. I would like to know too.
Old Dec 4, 2007 | 08:57 PM
bschulz's Avatar
If your are referring to the bracket-to-block bolts you will find the part number under the diagram for CYLINDER BLOCK-OIL PAN. Make sure you are looking at your particular block. For the bracket to mount bolt and nuts look at the ENGINE MOUNT diagram.
For engine related questions make sure you specify which engine you have a question about.
Old Dec 4, 2007 | 09:16 PM
Locrien's Avatar
Default Re: (bschulz)
I found it and I was assuming it was B series which I guess I shouldn't have.
I was talking about this one.
heres the bolt spec
12 x 1.25 mm torqued to 54 ft lbs
Old Dec 4, 2007 | 09:33 PM
bschulz's Avatar
Just for Del Sol on Roids reference that is a picture of a passenger side tranny mount, NOT the driver side motor mount.
Old Dec 4, 2007 | 09:51 PM
Locrien's Avatar
Wow can't believe I missed that. Thanks for the correction.
Heres the right pic for the OP.
MissKryss
Sep 3, 2018 10:12 PM
efyou
Jan 11, 2008 05:51 PM
216.226.142.95:27016
Jun 29, 2003 02:27 PM
maxxdout
Jan 2, 2003 12:01 PM
