Tapping fuse box for switched 12v
Old Sep 23, 2007 | 09:14 AM
JordanCivic's Avatar
Default Tapping fuse box for switched 12v
Hi guys, under the dash there are spaces on my fuse box with no fuses, Can the box of the fuse box be taken apart to add a new connection for a wideband? Is there something like a spade connection on the back of the fuse box??
Thanks
99 civic si
Old Sep 23, 2007 | 10:07 AM
standbackimapro's Avatar
Why dont you just splice into a power source on the car.. Splice the wideband power wire into somthing under the dash thats only on when the car comes on
Example: I Wired my friends power wire for his tach into behind a fuse that was on when the car came on, then i wired the illumiunation for the tach wire behind the Headlight fuse so it would light up when the headlights were on
Old Sep 23, 2007 | 10:10 AM
I want to use a 'clean' power source for my UEGO
Old Sep 23, 2007 | 11:00 AM
Hondaruss's Avatar
Default Re: (JordanCivic)
I spliced int to the ignition harness for the key so every time you turn the key on the gauge comes on. and no worries of blowing fuses.
Old Sep 23, 2007 | 11:56 AM
Chiovnidca's Avatar
Default Re: Tapping fuse box for switched 12v (JordanCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JordanCivic &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys, under the dash there are spaces on my fuse box with no fuses, Can the box of the fuse box be taken apart to add a new connection for a wideband? Is there something like a spade connection on the back of the fuse box??
Thanks
99 civic si</TD></TR></TABLE>
Look right above the fuses on the under dash fuse box. Should be 3-4 slots you can hook up to with a spade connector. Some are switched, some are not.
osbunjosh
50
Jan 29, 2024 05:20 PM
ExVtec
Honda S2000
17
Mar 18, 2009 05:19 PM
Turbo_Mike
Sep 9, 2006 05:14 PM
Boarderx192
Dec 5, 2005 07:35 AM
racecarpete
Audio / Security / Video
Mar 30, 2003 07:44 PM
