b16 all motor?
Old Sep 23, 2007 | 07:04 AM
94civiclover's Avatar
Default b16 all motor?
planning on buy a jdm b16 and was wondering what i can do to get at least 200 hp or more out of it already have a 4-1 dc sports header and also a cold air intake and aem pulleys any suggestions ?
Old Sep 23, 2007 | 07:23 AM
B16A CRX's Avatar
Default Re: b16 all motor? (94civiclover)
B16 200 whp. about 5 to 6 grand and a real good tuner. im on the same boat as u and thats around how much i've wasted already and im not sure i get to the 200 whp mark
Old Sep 23, 2007 | 07:25 AM
Default Re: b16 all motor? (B16A CRX)
im not looking for 200whp just 200hp overall
Old Sep 23, 2007 | 07:43 AM
B16A CRX's Avatar
oh well u can start by bumping your compression up with aftermarket pistons or oem. best oem pistons for your B16 are Ctr pistons which i have a set for sale. after that you shoul upgrade your valvetrain get some mild cams I/H/E intake manifold and a good tune. U should get a better header then a dc 4 to 1.
Old Sep 23, 2007 | 06:07 PM
Default Re: (B16A CRX)
how much for the pistons and also what do i have to do to the block for them to work and will i still be able to run on 93 gas?
Old Sep 24, 2007 | 12:02 PM
B16A CRX's Avatar
you will not have to do anythin to the block unless your sleeves are scratched. if your sleeves are scratched then you will have to hone them. I want 200 for the pisotns shipped. they are brand new with rings and all u have to do is shave 1mm off each side of your rods on the part that connects to the pistons. any machine shop can do that for you. I have some scat rods 4sale also they are for a B16 i can give u a good price if u buy both.
Old Sep 24, 2007 | 12:05 PM
onepoint6i's Avatar
toda is the best header for a B16
Old Sep 24, 2007 | 03:27 PM
American.Graffiti's Avatar
Default Re: (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A CRX &raquo;</TD></TR><TR><TD CLASS="quote">B16 200 whp. about 5 to 6 grand and a real good tuner. im on the same boat as u and thats around how much i've wasted already and im not sure i get to the 200 whp mark</TD></TR></TABLE>
Disregard what ^ said. $5,000 is way more than what you need to make 200whp on a b16. You can run some CTR pistons with some good cams (I.e. Rocket Motorsports M22x or something along those lines maybe even some Blox's cams which are around 200-300 cheaper than the competition.) with a Toda header (maybe even a SMSP header) and ITR intake manifold and throttle body and your gold, all that is on the cheap side with most of the money being spent on the header. Understand the fact that b16's have no power down low so you have to throw some parts in there to help make up for it up top. Now if you go all out you can spend $5k but thats with ITB's, forged pistons and sleeved. But if you are willing to go through all that you might as well save up a lil more and go K.
Oh and the guy above my post is also correct.
Old Sep 25, 2007 | 06:47 AM
IT GUY's Avatar
https://honda-tech.com/zerothread?id=1445185
^^200hp B16
Old Sep 25, 2007 | 02:32 PM
b20vtech's Avatar
this was a set-up a friend had
B16 block with CTR piston 81.5mm bore
hand sand gsr head LOL
itr cams
skunk2 manifold with stock TB
ITR header
produce 174whp and 110lbs. tq. i think he dint even spend a dime on this build...Very impressive for a garage part sale put together motor....LOL
Old Sep 26, 2007 | 11:54 AM
B16A CRX's Avatar
Default Re: (IT GUY)
if he wants the rev the motor more than 8k and still make power he might want to port and polish the head. And im pretty sure ill will spent atleast 5 grand on his B16
Old Sep 26, 2007 | 12:58 PM
IT GUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A CRX &raquo;</TD></TR><TR><TD CLASS="quote">if he wants the rev the motor more than 8k and still make power he might want to port and polish the head. And im pretty sure ill will spent atleast 5 grand on his B16</TD></TR></TABLE>
I dunno about 5k on just the motor, maybe with the ITBs but he still made 200hp without 'em. It really a pretty simple setup kinda like that omniman build
Long Block:
'00 SI B16A2
CTR PCT pistoins w/ honda rings std. bore (81mm)
ARP rod Bolts
ARP head studs
OEM head gasket, used 1 piece
Comptech Machine Street port w/ full radius valve job
ITR intake Valves
Portflow springs and retainers
Skunk Stage 2 cams and gears
ITR Intake manifold ported by Comptech Machine
ITR throttle body
MemoryFab J's style CarbonFiber Intake
Toda header
STr fuel rail
RC 310cc Injectors
CTR N-1 crank Pulley
Old Sep 26, 2007 | 01:58 PM
gunnerman's Avatar
i dont think you need to spend 5k to hit 200 whp....u might as well turbo for that price..makes more sense and you'll have alot more torque..
GrenadaEG2
Aug 9, 2009 01:32 PM
anothersickhatch
35
Oct 2, 2005 10:28 PM
markaria
Oct 10, 2004 06:23 PM
scaredoftheCRX
Jan 1, 2003 10:56 PM
