Sloppy shifter??????
Hey guys, I know this was posted previously, but I couldn't find the thread
. I have an 88 crx hf with b18c, I'm using the HCP kit with adjustable linkage, and the shifter is sloppy as hell. I can put it in first, and it has just as much play as it would in neutral.
I know someone had this problem before, just wondering what the fix was. I can go through all the gears, but it is too damn sloppy. Thanks in advance guys.
. I have an 88 crx hf with b18c, I'm using the HCP kit with adjustable linkage, and the shifter is sloppy as hell. I can put it in first, and it has just as much play as it would in neutral.I know someone had this problem before, just wondering what the fix was. I can go through all the gears, but it is too damn sloppy. Thanks in advance guys.
The linkage is tight, and it's on correctly, the shifter itself is just sloppy as hell. I have to find a way to fix this, because it will drive me crazy.
if the HCP ones are the type that are adjustable, then i seem to recall someone putting lock-tite or whatever on the threads to keep it from moving and adjusting. i dont know if this is 100% correct but i do remember hearing something about this on this board.
bullseye
Mar 27, 2004 10:40 PM
