Weard, dont know if its a tech Q
Last night i was going from a freeway onto a ramp to get on road and turning left while it was green, so i speed up to make into it. it was after a rain i dont know how fast i was going but pretty fast so i braked hind of hard to, to make it into a corner and my car just shuts off. Going into a corner was little hard sense the power steering was off and then my car just starts up and as it was it was good. Any ideas what could it be, checked my batt today the connectors was tight good, it was on my 93 prelude 5 speed
lol, w0rd... You're car shut off and came back on by itself?? That's crazy awesome...
Mine'll just shut off, and that's it...
Your Battery shouldn't have anything to do with it, the car isn't really running off the battery once it's already running..
Check your Dizzy/plugs/wires maybe? Fuel, air filter? So many things could make it stall...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 »</TD></TR><TR><TD CLASS="quote">lol, w0rd... You're car shut off and came back on by itself?? That's crazy awesome...
Check your Dizzy/plugs/wires maybe? Fuel, air filter? So many things could make it stall...</TD></TR></TABLE>
yeah i know its not the battery but some noobs will get in here and be like its your battery connectors man, ill check tommorow i hope it wont shut off on my on road or track, also does anyone know what that water hose called the one under the distubiter? i have a small hole in there and im losing coolent
Maybe check for any loose ground wires. That may cause it to cut out and come back on. it has happened to me before. just my thought.
And the hose you are talking about i believe is the water inlet hose to the heater core.
lol ya im kinda curious too. when it was raining, my uncle decided to do a donut and the car just shut off and then started again. wierd. is it like the ecu sensing something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CentralCalLude92 »</TD></TR><TR><TD CLASS="quote">Maybe check for any loose ground wires. That may cause it to cut out and come back on. it has happened to me before. just my thought.
And the hose you are talking about i believe is the water inlet hose to the heater core. </TD></TR></TABLE>
im sure its not the ground wire, cuz i have thouse ebay ground wires all over my engine bay lol, and sure that it wasnt the rain what caused it sense i drove after rain and my car was parked in different city sense i work there and there was no rain, but where i live there was rain and i was driving after rain.
that happened to me in my old toyota pickup before. i was taking a turn and it all of a sudden cut out. then it just started back up again. i never took it out of gear or used the clutch or anything so i guess it just roll started itself. i assumed it must have been so sort of ignition problem, and once it got spark back it started running again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CentralCalLude92 »</TD></TR><TR><TD CLASS="quote">Maybe check for any loose ground wires. That may cause it to cut out and come back on. it has happened to me before. just my thought. </TD></TR></TABLE>x2
check ur ecu ground, starter ground, tranny ground, and valve cover ground, make sure they are TIGHT.
Jolynn Crane
Nov 21, 2015 08:41 PM
