car will not stay on.
Old Sep 21, 2007 | 05:32 PM
MI4$DC5's Avatar
Default car will not stay on.
i swapped in a b20vtec and when i try to start my car up, it revs up to 3K and drops back down and dies out.
i swapped out the spark plugs for new ones. what else should i be checking and what can cause the car not to stay on?
Old Sep 21, 2007 | 05:39 PM
n8dizzel's Avatar
Default Re: car will not stay on. (MI4$DC5)
most important check all your wire harnesses from your engine to your ECU. Also make sure that ecu is the proper one for your motor and it is the correct OBD version.
All I can think of.
Old Sep 21, 2007 | 05:46 PM
jdm24seven's Avatar
Default Re: car will not stay on. (n8dizzel)
help him out!
Old Sep 21, 2007 | 06:05 PM
92hatchboi's Avatar
check all ur vacuum hoses and the intake manifold for leaks
Old Sep 21, 2007 | 06:33 PM
MI4$DC5's Avatar
Default Re: car will not stay on. (92hatchboi)
im going to check them now....crosses fingers
Old Sep 22, 2007 | 06:29 PM
MI4$DC5's Avatar
no leaks. car still starts up. goes to 3k and cuts off....anyone???????
Old Sep 22, 2007 | 07:13 PM
mycivicsi's Avatar
check your iac still if it is still good and also adjust your iddle screw
Old Sep 22, 2007 | 07:54 PM
MI4$DC5's Avatar
Default Re: car will not stay on. (mycivicsi)
alrighty, i will check that first thing in the morning
Old Sep 22, 2007 | 09:11 PM
Kusai.Nihonjin.Desu's Avatar
Check for spark and fuel.
Old Sep 22, 2007 | 09:47 PM
lovey408's Avatar
Default Re: car will not stay on. (Nihonjin.Desu)
i just picked up a 91 teg from a homie for free. it was parked at his house for a yr and wuld start up and die out.. so i did a lil tune up and noticed his spark plug wires were not in the right order on the distiburator... fixed it and it started right up perfectly.. did u try to check that?
Old Sep 22, 2007 | 09:49 PM
drtysohc's Avatar
it's either tuning or a wicked vacuum leak.
Old Sep 22, 2007 | 10:03 PM
about:blank's Avatar
that sucks
Old Oct 3, 2007 | 04:35 AM
MI4$DC5's Avatar
Default Re: car will not stay on. (about:blank)
fixed
Old Oct 3, 2007 | 04:39 AM
rleonekc's Avatar
Good deal
94LSmanual
Mar 22, 2008 06:38 PM
BALLIN H22 EK
Feb 24, 2006 12:36 PM
Lenne
Nov 6, 2005 09:50 AM
mustninty
17
May 24, 2004 12:52 PM
Trinity
13
Sep 4, 2002 06:01 PM
