d16y8/d15b7 build
Old Sep 21, 2007 | 05:30 PM
almostboostedgsr's Avatar
Default d16y8/d15b7 build
I bought a d15b7 full block from a friend for cheap. I plan on swapping on a y8 head. I know how to do the mini me process. So thats all covered.
I want to build the bottom end up on the d15b7. I heard that the b18a1 connecting rods could only work if it was in a d16. So thats out of the question.
Im trying to figure out what rods would work really well. Im leaning towards going forged.
Also the pistons. I know I should get 12/1 compression ones but what brand do you guys normally go with?
Im going to use the stock crank. Is there anything I need to do to the crank besides polishing it?
Next, I want to do a mild build on the head. Like a three angle valve job, cam, cam gear, valve springs, retainers. Would there be anything else needed.
If I could get some help and decent answers that would be great.
Also if you guys could post up some setups.
Ive already went through half of the sohc thread, but I need more info.
Thanks.
Old Sep 21, 2007 | 10:57 PM
Aquafina's Avatar
Get a D16 block.
Rods options are limited for the D15. If you keep the stock pistons and put a cam in it, you're in for problems.
Old Sep 22, 2007 | 02:13 PM
Default Re: (Aquafina)
Your statement is awfully wrong. Their is tons of mini me setups. Im just asking what type of pistons and rods should I be using for this.
Old Sep 22, 2007 | 02:19 PM
cartune network's Avatar
Default Re: (almostboostedgsr)
well with my all motor b i used je pistons and eagle h-beams. if ur gonna build it up i would reccomend getting the crank balanced and well the whole bottom end balanced.
if ur gonna do all that work to the head u might as well get a port on it. the sohc heads dont flow too well stock so opening up the bowls and the ports wouldnt be a bad idead especially if ur gonna run an aftermarket cam.
Old Sep 22, 2007 | 03:14 PM
Default Re: (cartune network)
Thanks alot. How much would an average port and polish run for a sohc. I know on the b-series its expensive since im a b owner as well.
Old Sep 22, 2007 | 03:48 PM
well it depends on whose doing the porting. i know if u send it to head games ull spend about 600 on a port. but if u just bring it to a machine shop ull probably spend about 400
Old Sep 22, 2007 | 04:15 PM
now one other thing. My d15b7 block has a slight chip on the outter edge top of cylinder #2. Would this affect anything?.
Old Sep 22, 2007 | 04:19 PM
Aquafina's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by almostboostedgsr &raquo;</TD></TR><TR><TD CLASS="quote">Your statement is awfully wrong. Their is tons of mini me setups. Im just asking what type of pistons and rods should I be using for this. </TD></TR></TABLE>
No. Rod options ARE limited for the D15. Put a big cam in a head that has bigger valves as well as the valves being closed to the side of the head and tell me you won't have problems.
Old Sep 22, 2007 | 04:25 PM
How would I have probelms?. I know the d15 is limited to rod choices. How would I have probelms if it has been done over and over again. This setup is just like doing an ls/vtec on a b-series.
If I cant get better rods, then ill have to buy new stock rods and have them shot peened.
Also in case I do run in to some probelms where can I get a d16 short block?
Old Sep 22, 2007 | 04:57 PM
Aquafina's Avatar
Valve reliefs are smaller as well as in a different location. Assuming you deck it to get compression, you'll run into problems with a cam.
New rods is just as bad as used rods. The rods are weak as are the rod bolts. You can get a D16 block just about anywhere. I got one for free once from a VW shop that was moving and had one.
98EGY8
Aug 22, 2015 10:53 AM
PhantomEJ1
35
Jul 6, 2011 09:18 AM
Matt91
12
Dec 12, 2009 08:27 PM
tinkertime
Apr 18, 2007 07:26 AM
Soulless
Dec 29, 2002 12:57 AM
