Throttle Body Information.
Old Sep 21, 2007 | 05:04 PM
K24.20A's Avatar
Default Throttle Body Information.
Will a bigger diameter throttle body improve more whp or tq? I have only basic bolts on such as i/h. Soon exhaust. Later cams, shafts, etc. Going all motor. Can anyone give me some input please.
Old Sep 21, 2007 | 06:08 PM
gianinline's Avatar
The amount of air that is going through the TB may be slightly (and that is...only slightly) bigger than before, but it all comes down to the same intake manifold. Unless you bore the inside of the manifold, and remove some material from inside of it, i doubt you would gain 1hp from it.....
What is the motor on your accord 2003???
Old Sep 21, 2007 | 06:10 PM
K24.20A's Avatar
Default Re: (gianinline)
k24a4 going all motor
Old Sep 21, 2007 | 06:20 PM
gianinline's Avatar
There is a variety of aftermarket parts of k24's already. I have a F22, which i'm building all motor as well.
I did some bolt-ons in the past, i was happy with the results.
From everything i had, the best stuff i had was: all aluminum pulleys, 8lb alluminum flywheels and stage 3 clutch. The car would rev up quickly, and just felt like it had lost a lot of weight.... was much quicker than before, great response from only such mods.
What kind of purpose do you plan on building your engine for? Daily driving? Track... both?
Also... what numbers do you wish to lay to the wheels???
Old Sep 21, 2007 | 08:42 PM
K24.20A's Avatar
I am doing daily driven, no track car but i want the extra power. willing to fork over $ but only for all motor setup. no fi / turbo. thanks for the input
Old Sep 23, 2007 | 01:00 PM
swappedaccord's Avatar
don't waste your money, i've seen people put larger diameter TB's on and lose hp. the only way you're going to get extra power out of TB is high-flow intake manifold and throw some boost in the mix
Oreo-TeCk
11
Apr 27, 2014 07:53 PM
98civtec
May 14, 2009 12:57 PM
SSGojeta
Dec 27, 2008 09:29 AM
fliP
Dec 30, 2004 10:28 AM
93jdmr
Jan 19, 2004 11:58 AM
